Thread: Oil leak exhaust headers
Results 1 to 7 of 7
  1. #1 Oil leak exhaust headers
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    :th_scratchhead
    First of all, Howdy to all....
    My son's 2000 GTP has oily mess around exhaust header and engine heads. When we removed exhaust headers, there were alot of oil on the exhaust header bolts. Engine doesn't burn oil, smokes, or makes noises. This started after installation of aftermarket headers. Any ideas?
  2. #2 Re: Oil leak exhaust headers
    Oklahoma
    My guess would be the valve cover gaskets.
  3. #3 Re: Oil leak exhaust headers
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    most likely, there is also a recall through GM for it, see your dealer to see if you need it fixed, either way FIX IT
    COMP G
  4. #4 Re: Oil leak exhaust headers
    Ohio
    ^ would be my guess as well. def fix it asap if it hasnt been done. watch it though cause i had mine done an they fu$%&@ it up an i had to redo it myself but now no probs at all.
    00 GTP demodded and forsale
  5. #5 Re: Oil leak exhaust headers
    TDCRacing
    Guest
    Valve cover gasket
  6. #6 Re: Oil leak exhaust headers
    Charles City, IA
    x5 valve cover gasket
    SMGPFC Two Nipple General
  7. #7 Re: Oil leak exhaust headers
    Thank you for quick responses all. We've pulled the motor, son is going to clean up motor and going to replace all gaskets. Plus do a few little mods to it. Once again, thanks... We'll keep you posted...
    GTP Dad
  1. XS Power Headers Vs. SSAC Headers
    By 04CompG in forum General Tech Discussion
    Last Post: 12-02-2008, 01:12 PM
  2. oil leak
    By whitegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2008, 03:48 AM
  3. Coolant Leak
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 02:56 PM
  4. Oil leak
    By fiveinthelive in forum General Tech Discussion
    Last Post: 03-11-2008, 09:35 AM
