Thread: sputtering and running rich!!
Results 1 to 12 of 12
  1. #1 sputtering and running rich!!
    Mar 2015
    indiana
    my 02 grand prix gtp is being weird latly any time I floor it it cuts out bad and some times randomly at cruising speeds it will randomly sputter! it has died while driving and at idle a few times but starts right back up! I have upgraded pcm from zzp, 3 inch downpipe (no cat), resonator, and cold air intake! the only code its throwing its fuel trim to rich bank 1! just changed upstream o2 sensor and still getting the problem I have a obd scanner that Bluetooth's to my phone but not sure what to look for on there can any one help what should I do next
  2. #2 Re: sputtering and running rich!!
    tune up time maybe. or the icm could be taking a crap, or a coil.
  3. #3 Re: sputtering and running rich!!
    Donating Users Uno99's Avatar
    Appleton, Wi
    When did this start? Was it after a mod you added or after you worked on the car. Coil was a thought as well or Your fuel trims most likely need to be reset. Google or search here how to reset these maybe by a battery disconnect or fuse pull. I know when my fuel trim were way fat i had similar issues. Any accel under load and it would fall on its face and sputter. I would also get ahold of zoomer at zzp give him some of your data and have them lean out the tune.
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  4. #4 Re: sputtering and running rich!!
    Mar 2015
    indiana
    Can't remember exactly when it started but wasn't directly after any mod I had them all on for quite some time b4 it started!!
  5. #5 Re: sputtering and running rich!!
    Appleton, Wi
    When was the tune added? Do you have your old pcm to swap back in. If not check your plugs wires then maybe head to the junkyard and get some coil packs try those shouldn't be too expensive
  6. #6 Re: sputtering and running rich!!
    Mar 2015
    indiana
    The pcm was added over a year ago and I don't have the old one sent it to zzp for core! And I just chaged coils today no luck still
  7. #7 Re: sputtering and running rich!!
    Appleton, Wi
    How to the plugs look? What brand O2 sensor did you swap in. Also is your throttle body dirty? I say disconnect the battery then check the plugs, clean TB. Hookup battery then go for a good 30 min drive. Start out easy and try to drive at different speeds/loads then slowley get a bit more aggressive and see if it gets better. Keep trying things man you figure ot out sooner or later.
  8. #8 Re: sputtering and running rich!!
    Mar 2015
    indiana
    Ok so now I've changed O2 sensor,coil packs, spark plug and wires! And it's continued to get worse died 5 times on highway on my way to work taking longer to get started sometimes it will die and start right back up other times it dies and takes several times to get it started again what's my next try at it? I was thinking fuel pump but don't wanna spend 200 If that's not it
  9. #9 Re: sputtering and running rich!!
    I guess MAF sensor at this point.
    If you know anyone with another 3800 from 99-03 you could do a quick swap and find out before you buy a new one.
  10. #10 Re: sputtering and running rich!!
    Donating Users timboku's Avatar
    Montgomery, IL
    Unplug the maf sensor see if that helps it not die out...I would guess maf sensor as well...or possible icm failing.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  11. #11 Re: sputtering and running rich!!
    Mar 2015
    indiana
    Wouldn't maf be throwing a check engine light or some kind of code? Only code I've got is rich in bank 1 and that went away after I changed the O2 sensor so I currently have no codes
  12. #12 Re: sputtering and running rich!!
    Mar 2015
    indiana
    Ok guys I'm thinking it is my maf sensor but I unplugged it took it for a drive and it still died! My long term fuel trim is at -10 unplugged maf got my LTFT down to -1
  1. 2000 GTP Running Rich
    By addeible in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2013, 12:27 PM
  2. Running too rich?
    By 94GrandPrixSE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-18-2013, 09:43 AM
  3. Car is running rich... I think
    By ElAlacran2010 in forum General Tech Discussion
    Last Post: 02-25-2011, 08:51 AM
  4. Running rich
    By saleenprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2010, 08:53 AM
  5. car running really rich
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2009, 04:48 PM
