Thread: Larger throttle body for 04+??
Results 1 to 12 of 12
  1. #1 Larger throttle body for 04+??
    Mar 2015
    Montana
    Im sure this has been asked a thousand times, but is there any alternative for a larger throttle body for the 04+ GTP cars? or is there a substitute? Or has anyone converted to cable? Thanks guys for the help, I sold my 97 GTP, kinda wishing I hadnt!! LOL
  2. #2 Re: Larger throttle body for 04+??
    No need, doubt your out flowing it
    04 Comp G.
  3. #3 Re: Larger throttle body for 04+??
    What he said.
    Also you couldnt really change it if you wanted, there really is no way to tune for it with these computers. You couldnt ever switch to a cable TB either, everything is electrical these days and everything talks to each other.
  4. #4 Re: Larger throttle body for 04+??
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    What they have all said. And I've looked for my own car came up with bupkiss
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  5. #5 Re: Larger throttle body for 04+??
    Why do you think you need one, that's my question.
  6. #6 Re: Larger throttle body for 04+??
    GT Level Member Overkill's Avatar
    Nanaimo British Columbia
    I hope to have something to talk about soon. I imagine it'll be worthwhile on cammed vehicles the most. The stock TB blade isnt a bad size but the housing is pretty crap.
    Email all inquiries to willoverkill@gmail.com!
  7. #7 Re: Larger throttle body for 04+??
    hangover park IL
    i was ****ing with a 3800 TAC and the earlier GM 90mm DBW TB. the motor controls and the sensor trace outputs are the same, the problem is then that you have to find a place to put a hacked TAC module and just run the pigtails to the vette tb.
    a 90mm tb was marginal on a 2300ax with a 3"....probably not a huge gain by any means for a tiny m90
    on a side note im finally starting to see the PPS glitching out on my 04....getting worse by **** hairs at a time...
    rpm dropout when letting off as you go below 9%.
    im gonna call it where instead of tb mounted tps' like the good old days....youll start seeing replacement of the PPS and DBW TB's as they all experience wear in the most traveled area's of the carbon track.
    awesome progress....
    ~James~ Psychotic Gearhead
  8. #8 Re: Larger throttle body for 04+??
    Mar 2015
    Montana
    thanks guys, I appreciate all the help, I know I wouldnt be out flowing it, just thinking about future upgrades, does anyone know the stock size?? I should know I guess...
  9. #9 Re: Larger throttle body for 04+??
    I thought they were 65mm, and the LS4 is 10mm larger than that if I remember right.
    It is also drive by wire, but you'd have to figure out pin outs to make it work, if it even would.
    Plenty of LS4 guys run LS2 throttle bodies and change the pinouts after manifold swaps.
  10. #10 Re: Larger throttle body for 04+??
    Mar 2015
    Montana
    cool thanks
  11. #11 Re: Larger throttle body for 04+??
    78mm 04+ throttle body is in testing...
  12. #12 Re: Larger throttle body for 04+??
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    Subscribed.. I need one..
    2004 Comp G "The Panda"- low, e85, big brakes SOLD
    2002 Trans Am- 6 speed, bolt ons or something, it's slow.
    2006 Silverado- forged ls2, 4l80e, plate kit, also slow...
  1. Detaching and Reattaching Throttle Cables to L67 Throttle Body
    By komrad36 in forum How To Write-Ups/Tech Tips
    Last Post: 05-01-2017, 12:09 PM
  2. N* throttle body
    By 1BadGT in forum Introductions/Noob Questions
    Last Post: 10-30-2014, 08:28 PM
  3. Larger Cam With Larger Rocker Ratio's?
    By pontiackid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-20-2009, 02:29 PM
