Thread: Spark plug heat range
Results 1 to 3 of 3
  1. #1 Spark plug heat range
    GT Level Member xxburkettxx07's Avatar
    Topeka, ks
    Should I use a autolite 104 or 105 when using 3.4 pulley 3"down pipe cold air t stat??
  2. #2 Re: Spark plug heat range
    Stock thermostat and 605's should be fine. No reason to go 104's, you don't need plugs that cold.
  3. #3 Re: Spark plug heat range
    Topeka, ks
    I got 605s already have 180t stat need a part number for Oreilys supercharger belt for the 3.4 pulley
  1. spark plug gap range is best?
    By fst in forum Turbo
    Last Post: 01-31-2011, 08:50 AM
  2. Spark Plug Heat Sheild?
    By Jazzy19 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-30-2010, 08:49 AM
  3. Spark Plug Heat Range Question
    By Agentlongwood in forum General Tech Discussion
    Last Post: 11-09-2009, 03:25 PM
  4. plug heat range....
    Last Post: 08-12-2009, 06:30 PM
  5. plug heat range question
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-03-2008, 03:03 AM
