I plan on getting some Hinson heads done for a build I am thinking about. Nothing like Stage 4 ported heads but just enough which seems a lot go for. I am pretty sure I want to go Intense S3x cam but should I even consider an S2x?
130# crows and Manley retainers will be used. What's the most problem free timing setup out there right now for a build like mine? Is a Jp single roller or Rollmaster okay? Or is a double roller required? < machined front cover and oilpump cover needed from what I remember?
I will be stock lower end and will be using genuine Gm headgaskets. Should I even think about doing head studs?
