Thread: Cranks but no start
Results 1 to 3 of 3
  1. #1 Cranks but no start
    SE Level Member 3rdgen's Avatar
    Kingston Ma
    I have an 07 gtp that cranks but wont start can hear fuel pump no spark no injector pulse. Tried swapping the icm and still won't start also tried swapping the crank sensor. Any ideas I am beginning to think its the pcm at this point?
    2005 TS Monte SS, 3.5MP,ZZP HVTB,104's,K&N CAI,ZZP Swain Coated Headers,OverKill PCM,HRR 1.9
  2. #2 Re: Cranks but no start
    Check all IGN fuses.
    Check ground under ICM bracket.
    I doubt it's a computer problem.
  3. #3 Re: Cranks but no start
    Sep 2011
    Canada
    If it cranks but no start then the fuel isn't igniting. Do you smell fuel? A bad fuel pressure regulator can cause this issue. Bad coil, fuses and electrical ground like fivefingers said too. Do you have any engine codes?
  1. Cranks But Won't Start.
    By Paintball0027 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-20-2015, 12:49 PM
  2. cranks no start
    By GTPSHAWTY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2014, 06:09 PM
  3. Cranks but won't start
    By Thompsju in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-25-2013, 03:41 PM
  4. Car Won't Start... Just Cranks.
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2010, 10:23 PM
  5. Cranks over but will not start
    By wfj8251 in forum General Tech Discussion
    Last Post: 02-08-2009, 02:47 PM
