Thread: engine code P1133
Results 1 to 20 of 28
  1. #1 engine code P1133
    Kemmerer, Wyoming
    I have been getting an engine code P1133 and have been trying to figure out what would cause it. its for the front O2 sensor, but there are a couple different thing that could cause it. I had one exhaust leak that I fixed, and I might have another, but its probably not as bad as the first.
  2. #2 Re: engine code P1133
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Do you have headers?
    04 GTP -HAI, 1.9 rockers.
  3. #3 Re: engine code P1133
    Kemmerer, Wyoming
    ya, sd headers. the first leak I fixed was at the junction of the front manifold with the crossover.
  4. #4 Re: engine code P1133
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    sub'd because i have the same problem!
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  5. #5 Re: engine code P1133
    Aug 2013
    Sandy, UT
    Headers even with no leak will cause that code often. Something to do with more flow and the O2 sensor has trouble keeping up. Or the O2 can be bad, but that code is tuned out on both my cars and 2 of my friends cars. Its really not any issue, if you have a new O2 sensor or you verified that the O2 is working.
  6. #6 Re: engine code P1133
    Kemmerer, Wyoming
    if the o2 sensor is working properly, and there are no leaks, then there will be no decrease in performance even if the code is still present?
  7. #7 Re: engine code P1133
    Aug 2013
    Sandy, UT
    Nope, Just check your O2 readings with the tq app or similar, as long as its bouncing from like .2ish to .8ish youre fine. Something that some people have good luck with and others don't is the spark plug non fowler trick.
  8. #8 Re: engine code P1133
    Jun 2012
    Illinois
    my car has a knocking problem that i have read that could be because of this code. Do you have any means of scanning to check? Hopefully someone has a solution other than tuning it out.
  9. #9 Re: engine code P1133
    Aug 2013
    Sandy, UT
    Its either a bad O2, or you delete the code, or the non fowler trick. A new O2 would be a good idea.
  10. #10 Re: engine code P1133
    Jun 2012
    Illinois
    I thought the non fouler trick was only for the post cat catalytic sensor to deal with the P0420 code? How could you fit those nonfoulers in there?
  11. #11 Re: engine code P1133
    Aug 2013
    Sandy, UT
    Some have also had luck with it fixing the slow response code, I wouldn't try it because it may also mess with the fueling readings its seeing.
  12. #12 Re: engine code P1133
    Jun 2012
    Illinois
    so the only solution is to get it tuned out?
  13. #13 Re: engine code P1133
    Aug 2013
    Sandy, UT
    Yep tuned out or New O2 if you haven't tried that. Some cars throw it some don't. And ac delco or one other brand sensor.. some aftermarket sensor brands are sh1t.
  14. #14 Re: engine code P1133
    Kemmerer, Wyoming
    Tuning it out on a 99 should be fine, it was 2001+ that had issues when it's tuned out
  15. #15 Re: engine code P1133
    Aug 2013
    Sandy, UT
    No its the rear O2 that b1tches on 01+, but it can be succesfully tuned on even on 01+ with tiny tuner
  16. #16 Re: engine code P1133
    Aug 2013
    Sandy, UT
    Also, you aren't tuning out the whole o2, just turning off reporting for the one cel.
  17. #17 Re: engine code P1133
    Jun 2012
    Illinois
    mines an 01... not sure what op has
  18. #18 Re: engine code P1133
    Kemmerer, Wyoming
    I assumed by your name you had a 99 gtp. mine is a 2001 as well. I dont know anyone that has a tiny tuner. I am going to try the rear O2 sensor first and if that dosent fix it I will try the front. I dont think its the front because on the aeroforce the numbers fluctuate like they should, but the rear numbers dont fit into the range that they should, I think around 500, and they dont change fast at all.
  19. #19 Re: engine code P1133
    Aug 2013
    Sandy, UT
    rear O2 has absolutely nothing to do with the code you posted, you don't need tiny tuner to turn off this code or any code, You only need tiny tuner to stop the pcm from performing cat checks if you are catless. HPT or any tuning system will delete this codes.
  20. #20 Re: engine code P1133
    Kemmerer, Wyoming
    thanks for the clarification, I must have an exhaust leak or the headers are causing the code and will have to be tuned out.
  1. p1133 ?? what is this code
    By 1bad3800 in forum General Tech Discussion
    Last Post: 12-14-2016, 12:12 PM
  2. Service Engine Soon: Grand Prix GT 3800: P0102 & P1133
    By geeksweep in forum General Tech Discussion
    Last Post: 06-20-2013, 11:13 AM
  3. Header o2 Sensor Code P1133 Help
    By brandonl2000 in forum General Tech Discussion
    Last Post: 02-17-2012, 12:27 PM
  4. p1133 code
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-03-2011, 10:57 PM
  5. P1133 Engine not running smooth?????
    By Gearhed42 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-21-2008, 12:23 PM
