Thread: Probably a dumb question..
Results 1 to 8 of 8
  1. #1 Probably a dumb question..
    Sep 2014
    Rhode Island
    So this is probably a dumb question but, I started changing my spark plugs. I got my front plugs and wires out fine, but i have no idea how to get the rears out. Does anyone have any tips and tricks for removing plugs. Thanks.
  2. #2 Re: Probably a dumb question..
    I lean down and pull the wire off, then remove the plug with a plug socket, maybe a short extension and ratchet. If you find clearance to be an issue.. you can undo the driverside upper mount, then undo the bolt at the motor for the passenger side one.. rock motor forward and put bolt into the back hole. That'll give you a little more room.
  3. #3 Re: Probably a dumb question..
    ^^^^^ how i do it, as i got huge hands and need the room to work in. pulling the engine forward also lets you see what your doing better. the end plug by the o2 sensor can be a bit of a pita. i put the socket on the plug, then with a ratchet and a 3 inch extension just the tip fits into the socket, break it free and take it out.
    if using a real plug socket, its got a bolt on the top, you can use a wrench on it if you cant get the ratchet on clean.
  4. #4 Re: Probably a dumb question..
    You mean how the real plug sockets look like the head of a bolt at the end.
  5. #5 Re: Probably a dumb question..
    and that plush foam insert lol to keep the plugs from cracking. or the plug from falling out of the socket.
  6. #6 Re: Probably a dumb question..
    GT Level Member jrb1027's Avatar
    Jun 2013
    brookville,IN
    ive never had an issue reaching mine, i can change them in 5 minutes with a universal joint socket
  7. #7 Re: Probably a dumb question..
    i'll add this, with all them brackets removed and headers installed, theres no reason to move the engine any more for me. i can see and reach in there just fine now.
  8. #8 Re: Probably a dumb question..
    Jun 2013
    brookville,IN
    Oh I have headers thats pry why its so easy
  1. Probably a dumb question, but.....
    By Kilroy in forum Audio, Security & Visual Electronics
    Last Post: 07-10-2013, 06:52 PM
  2. Dumb question......
    By comatoast in forum General Tech Discussion
    Last Post: 12-07-2012, 09:15 AM
  3. Dumb question about LIM and MPH
    By gotgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-30-2012, 09:57 AM
  4. Hopefully Last dumb AC Question
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 12:48 PM
  5. Dumb question of the day
    By johnb62 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-06-2010, 12:13 AM
