Ive got low oil pressure on my 2006 supercharged 3.8L 153K mi. I put a mechanical oil pressure gauge on it; when I start it up cold it idles with 50+ oil psi, but when it warms up it idles at 5 psi and has 25 psi at 2500 rpm. I changed oil and put mobil 1 synthetic 15w-50 in and it didn't make any difference. I cut the old oil filter apart and there are no shavings so I don't think the bearings are going out of it, plus the motor sounds fine; no bad noises. I took the oil filter housing off to inspect the spring and plunger and they look ok and the plunger moves freely in the bore. Has anyone else experienced similar symptoms and found a solution?
