Few drops of oil won't lower oil pressure. It's got to a big gusher bleeding off almost all the pressure. If you were one of my customer, the installation of a manual oil pressure showed low pressure at normal engine temp.. No internal engine noise...small oil leak around the oil pressure feed / timing cover. No sludge in the valve train area... Recommend removing the timing cover for inspection.
