Thread: Camshaft?
Results 1 to 20 of 39
  1. #1 Camshaft?
    Aug 2008
    kansas
    i have an 02 gtp with down pipe u bend delete wizzaird cai, 18o tstat, tr55ix plugs, msd wires. have ordered a set of slp headers and and now looking at a cam. I want to run stock heads that are port and polished. What cam should i run?
  2. #2 Re: Camshaft?
    Banned
    oswego
    I think the S1X cam from intense is right up your alley. Great cam for stock heads. Personally i'm going to run the xp cam but i'm using nitrous to take advantage of the exhaust duration on it. There's also the NIC from ZZP which is a crazy cam for non-i/c'd cars but it's really aggressive and not the best daily driver cam, not to mention you need a really experienced 3800 tuner to get it running correctly. That's just a little info i can throw your way.
  3. #3 Re: Camshaft?
    i vote s1x as well. it's got a more usable powerband than the xp for street use.
    i would love to go cammed again, but im not putting that kind of money into this car anymore. if i would, id either get a NIC or TEP. both mean, mean cams that you can run on stock heads.
  4. #4 Re: Camshaft?
    Aug 2008
    kansas
    thanks guys!!! yea its my daily driver so i just want to feel some more pull.. not looking for anything too crazy, its just once i do something to my car its ok for a little while then i need more. its like an addiction and it always takes just a little more to get that high!! Great forum and great people here!!!
  5. #5 Re: Camshaft?
    Apr 2009
    Lima, Oh
    anybody out there using the VS cam from ZZP? i was looking at it and it caught my attention. im comparing it to the comp cam extreme energy cam.. anyone out there with any advice would be greatly appreciated
    2002 Black GTP, 3.2 pulley, CAI, Pacesetter Headers, 180 thermostat, xp cam, L32 rods, zzp pcm, N* TB, FWI
  6. #6 Re: Camshaft?
    The VS cam is better than stock for sure but it usually put on intercooled cars...a guy here is running mid 12's on a GenV and VS with no IC and headers...but is a tuning genius so who knows.
  7. #7 Re: Camshaft?
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by JayGTP02 View Post
    There's plenty of people running the VS cam, but I'm confused on what you're asking for. What cam are you trying to compare it to? Comp Cams Xtreme Energy is a style of lobe Comp makes, with a whole variety of lifts and durations available. IIRC, the VS cam uses an Xtreme Energy lobe on the intake side, and an Xtreme 4X4 lobe on the exhaust side. I believe Comp has put together some cams for the L67 with the Xtreme Energy lobes, but they had a few different ones available last I checked.
    2001 Buick Regal LS - Almost Stock
  8. #8 Re: Camshaft?
    Here...read up to figure out your decision...
    http://www.grandprixforums.net/f18/cam-specs-747.html
  9. #9 Re: Camshaft?
  10. #10 Re: Camshaft?
    QCA, IA
    a VS is a waste of money. get a bigger cam.
    LOL, sure, because someone who just wants a mild daily driver needs an XPZ, right?
  11. #11 Re: Camshaft?
  12. #12 Re: Camshaft?
    Apr 2009
    Lima, Oh
    this might be a stupid question.. but what does the N/A mean next to the cam specs for the XPZ?
  13. #13 Re: Camshaft?
    not sure what you mean...i dont even see where they published the specs, but i will tell you it is probably one of the best cams for an m90 setup. it is a smaller cam, which is shown with how you can run 1.7:1 rockers with it.
    if i were to go with another cam i would go with something HUGE. something at least in the .575 area for both intake/exhaust lift.
  14. #14 Re: Camshaft?
    QCA, IA
    It means Not Available, they don't give out the specs for it.
  15. #15 Re: Camshaft?
    Donating Users blowfishRus6's Avatar
    g.a.
    bigger is not always better....
    somebody had to say it.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  16. #16 Re: Camshaft?
    Dec 2008
    Canada
  17. #17 Re: Camshaft?
    Dec 2008
    Canada
    Quote Originally Posted by blowfishRus6 View Post
    This is true, if your planning on getting head work done take a list of cams to your machinist and get your heads flown and tested. They can tell you what the best cam is for your heads and if you want to you can get a cam ground to your own specs for optimum performance
  18. #18 Re: Camshaft?
  19. #19 Re: Camshaft?
    g.a.
    bobbies ..
    its slow.
  20. #20 Re: Camshaft?
    Dec 2008
    Canada
    i need videos of that cam, stat.
    Oh really? Maybe I have the headwork done already?
  1. Trouble History With Camshaft Position Sensor
    By SyntheticShield in forum General Tech Discussion
    Last Post: 06-04-2009, 01:21 PM
