Thread: Starter wiring?
Results 1 to 20 of 25
  1. #1 Starter wiring?
    Banned
    Jan 2013
    maryland
    Does anybody have a pic of their starter wired up? Tried to start to start the car and i saw smoke so it might have wired it wrong thanks
    Sent from my LG-E980 using Tapatalk
  2. #2 Re: Starter wiring?
    google turned this up.
  3. #3 Re: Starter wiring?
    Banned
    Jan 2013
    maryland
    Thanks man! So 3wires power and ground goes to that bolt above the small 8mm bolt?
  4. #4 Re: Starter wiring?
    the battey pos cable goes to the starter, that other fat eye loop with 2 wires to the same stud, bolt it down. then the one purple wire to the forward facing small stud.
    the battery neg cable goes to the trans bell housing with another eye loop or two. aka your main grounds.
  5. #5 Re: Starter wiring?
    Banned
    Jan 2013
    maryland
    This is the way its wired
  6. #6 Re: Starter wiring?
    get me another angle of that. like of where the wires are bolted on. it looks like you got way to much on there.
  7. #7 Re: Starter wiring?
    The furthest wires.. the two small black ones in the loom by themselves..that's your grounds that should go with the neg battery cable to the trans.
  8. #8 Re: Starter wiring?
    Banned
    Jan 2013
    maryland
    Power and ground got it thanks bill king of the 3800 lol scotty the prince of 3800 answers
  9. #9 Re: Starter wiring?
    nothing should be on the lower large stud, the pos cable should be up top, with that other wire that fits the large stud.
  10. #10 Re: Starter wiring?
    Jay.. I think you read that wrong.
    The starter gets it's positive battery cable, then the orange and black (same gauge thickness as orange), That's it!
    The stud on the transmission where the batter ground cable is ..gets those other two small black wires with it for sensor grounds.
    In this picture the starter is fully hooked up. Yet you see those other two small grounds I mentioned hanging there. That's because at the time of the pic, I had not hooked them to the transmission stud yet.
  11. #11 Re: Starter wiring?
    Banned
    Jan 2013
    maryland
    Might have a bad starter... or f*** wiring idk... hooked the wires the right way and as soon as i hook my negative side of the battery up my starter starts to come on... negative (black) trans connections are hooked to the trans..positive and other long connection hooked up fuseble link is hook by itself.. man i wish i took a picture before i removed them up.. any ideas? Thanks guys
  12. #12 Re: Starter wiring?
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    The ground gets the fat battery negative cable and the 2 little black wires with individual eyes.
    The positive gets the thicker orange wire and the 2 black wires that share the same connecting eye.
    The little purple wire goes to the stud below the positive position.
  13. #13 Re: Starter wiring?
    The reason the starter kicks the second you connect the battery is because either your positive cable or one of the two other wires are touching the soleniod (purple wire) connection as well.
  14. #14 Re: Starter wiring?
    Banned
    Jan 2013
    maryland
    Ok i'll swap try and move them away when i tighten them with the ratchet
    Thanks guys
  15. #15 Re: Starter wiring?
    You will have success
  16. #16 Re: Starter wiring?
    Banned
    Jan 2013
    maryland
    Lls yeah i know hopefully
  17. #17 Re: Starter wiring?
    I'm telling you ... as BillBoost what the issue is and how to fix it. It's loosen one 13mm nut, hold the wires in the proper orientation and tighten the same nut.
    I'm confident that you can do it.
  18. #18 Re: Starter wiring?
    Banned
    Jan 2013
    maryland
    Lol haha!.. my last build the starter was already on the motor and when i replaced the starter on that motor everything was in my face to no which went where but i gave bad memory man bad lls
  19. #19 Re: Starter wiring?
    Soooo it's fixed? Cause you are making Tyler all sorts of upset..lol
  20. #20 Re: Starter wiring?
    Banned
    Jan 2013
    maryland
    Its fixed bill lol i started the car already lol forgot to update my bad
  1. Starter Wiring Issue
    By AStanchiu in forum General Tech Discussion
    Last Post: 11-18-2012, 07:30 PM
  2. Starter Wiring Clarification Needed
    By Elite6 in forum General Tech Discussion
    Last Post: 08-24-2012, 10:22 AM
  3. Wiring the Starter
    By brandonl2000 in forum General Tech Discussion
    Last Post: 11-28-2010, 09:59 AM
  4. Need help with a starter...
    By kcbuckeye2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-29-2010, 12:14 PM
