Does anybody have a pic of their starter wired up? Tried to start to start the car and i saw smoke so it might have wired it wrong thanks
Sent from my LG-E980 using Tapatalk
Thanks man! So 3wires power and ground goes to that bolt above the small 8mm bolt?
the battey pos cable goes to the starter, that other fat eye loop with 2 wires to the same stud, bolt it down. then the one purple wire to the forward facing small stud.
the battery neg cable goes to the trans bell housing with another eye loop or two. aka your main grounds.
This is the way its wired
The furthest wires.. the two small black ones in the loom by themselves..that's your grounds that should go with the neg battery cable to the trans.
Power and ground got it thanks bill king of the 3800 lol scotty the prince of 3800 answers
Jay.. I think you read that wrong.
The starter gets it's positive battery cable, then the orange and black (same gauge thickness as orange), That's it!
The stud on the transmission where the batter ground cable is ..gets those other two small black wires with it for sensor grounds.
In this picture the starter is fully hooked up. Yet you see those other two small grounds I mentioned hanging there. That's because at the time of the pic, I had not hooked them to the transmission stud yet.
Might have a bad starter... or f*** wiring idk... hooked the wires the right way and as soon as i hook my negative side of the battery up my starter starts to come on... negative (black) trans connections are hooked to the trans..positive and other long connection hooked up fuseble link is hook by itself.. man i wish i took a picture before i removed them up.. any ideas? Thanks guys
The ground gets the fat battery negative cable and the 2 little black wires with individual eyes.
The positive gets the thicker orange wire and the 2 black wires that share the same connecting eye.
The little purple wire goes to the stud below the positive position.
The reason the starter kicks the second you connect the battery is because either your positive cable or one of the two other wires are touching the soleniod (purple wire) connection as well.
I'm telling you ... as BillBoost what the issue is and how to fix it. It's loosen one 13mm nut, hold the wires in the proper orientation and tighten the same nut.
I'm confident that you can do it.
