Thread: 2004 Grand Prix GTP Comp G Throttle Body
Results 1 to 17 of 17
  1. #1 2004 Grand Prix GTP Comp G Throttle Body
    Jul 2014
    Fort Wayne
    Need help, believe I need to replace throttle body. Butterfly is not opening all the way, I am looking on line for part (ebay). Although the part number does not match the number on the top of housing. Need to know cross reference? Also will a series II engine have the same one?
  2. #2 Re: 2004 Grand Prix GTP Comp G Throttle Body
    Did you try cleaning it first?
    04 Comp G.
  3. #3 Re: 2004 Grand Prix GTP Comp G Throttle Body
    Jul 2014
    Fort Wayne
    What do you mean clean it?
  4. #4 Re: 2004 Grand Prix GTP Comp G Throttle Body
    Take it off and use throttle body cleaner on the inside and use either and/or a rag or toothbrush to clean all the gunk and carbon off.
    04 Comp G.
  5. #5 Re: 2004 Grand Prix GTP Comp G Throttle Body
    Jul 2014
    Fort Wayne
    Ohh, there is no gunk or carbon on it. It is clean free and clear.
  6. #6 Re: 2004 Grand Prix GTP Comp G Throttle Body
    Enfield, CT
    1.Disconnect the wires from the TB.
    2.Take off the TB and spray carb cleaner all over the inside of the TB
    3. Use a paper towel to get the rest of the carbon build up off.
    4.Clean it perfectly
    5. Install and test drive for a week
  7. #7 Re: 2004 Grand Prix GTP Comp G Throttle Body
    Enfield, CT
    I type too damn slow.....
  8. #8 Re: 2004 Grand Prix GTP Comp G Throttle Body
    Jul 2014
    Fort Wayne
    Car has 234,000 on it, sensors says throttle position issue. It is attached to the throttle body directly.
  9. #9 Re: 2004 Grand Prix GTP Comp G Throttle Body
    Jul 2014
    Fort Wayne
    unit is clean, no carbon build up. throttle position sensor is throwing an error. car has 234,000 miles on it
  10. #10 Re: 2004 Grand Prix GTP Comp G Throttle Body
    Enfield, CT
    Quote Originally Posted by eadspj View Post
    We know it is attached to the throttle body directly.... Get a low mileage one from the JY and try that. Linkage is probably worn to hell
  11. #11 Re: 2004 Grand Prix GTP Comp G Throttle Body
    Jul 2014
    Fort Wayne
    Right, but what all does it cross reference with? Is it the same as non-supercharged engine? Is a series II the same?
  12. #12 2004 Grand Prix GTP Comp G Throttle Body
    Nope needs to be series 3..series 2 wasn't drive by wire. Just grab one from a 04-08 L26 or L32 doesn't matter if it's SC or not.
    04 Comp G.
  13. #13 Re: 2004 Grand Prix GTP Comp G Throttle Body
    Jul 2014
    Fort Wayne
    Thank you, figure II would not work. Have been getting conflicting information, agree with yard idea however wondering of the units sold on e-bay (rang from 100 to 400). I am concerned as I am aware you get what you pay for with electronics.
  14. #14 Re: 2004 Grand Prix GTP Comp G Throttle Body
    GT Level Member WolvesSoulZ's Avatar
    Québec
    When you say it's clean, I am sure you are speaking of what you see and not what you don't see (Engine side of the throttle body.) I can assure you that at 234k it's pitch black and needs to be soaked up really good.
    If you buy a new one, make sure it shines on both sides.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  15. #15 Re: 2004 Grand Prix GTP Comp G Throttle Body
    Jul 2014
    Fort Wayne
    I know it is clean because I have cleaned it myself. The ones on E-bay are new ones, company by the name of Harko out of Florida and others. Units look good but since after market and cost difference don't know if there is a real difference on the units. Throttle body is pretty simple so assuming the electronics may be substandard but not sure.
  16. #16 Re: 2004 Grand Prix GTP Comp G Throttle Body
    If your down for a little drive I have a spare tb you could swap on and see if it's any better
  17. #17 Re: 2004 Grand Prix GTP Comp G Throttle Body
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    12582615 and 12573670 are both 04+ l26/l32 throttle bodies used
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  1. 2004 Grand Prix GTP COMP G
    By slgrnvlfire in forum For Sale - Vehicles
    Last Post: 10-25-2013, 03:30 PM
  2. 2004 Grand Prix GTP Comp G - $6,950
    By GTPpower in forum For Sale - Vehicles
    Last Post: 07-06-2013, 12:09 AM
  3. 2004 Grand Prix GTP Comp G
    By 91z in forum For Sale - Vehicles
    Last Post: 05-21-2013, 10:20 PM
