Thread: Top swap
Page 6 of 7 FirstFirst ... 4567 LastLast
Results 101 to 120 of 133
  1. #101 Re: Top swap
    Banned
    Feb 2014
    Grand Blanc/ Flint
    This is my plan. Like it or not.
    Ported heads with valve job and new seals.
    Ported lim
    Headers
    Full exhaust
    Cai
    180tstat
    Tune
  2. #102 Re: Top swap
    Banned
    Feb 2014
    Grand Blanc/ Flint
    Not bad for a decent start
  3. #103 Re: Top swap
    GT Level Member atj8's Avatar
    Midwest
    I just took a online questionnaire .. I am now also a certified mechanic so ask away.
    Lmao so did I! Hell with my 4 year degree in engineering! This only took 10 mins! I feel like hes gonna put everything together than be like the regal kid and have a thread bashing everyones help. Calling it now! Lol
    98 GTP Gen v 2.8,FSIC,xpcammed,SD headers,CAI,CORNFEED,TIMBOKU TUNED
    04 Comp-g Turbo,Cornfed, TIMBOKU tuned
  4. #104 Re: Top swap
    Apr 2012
    Bancroft. Ontario, Canada
    inb4parrents say no again
  5. #105 Re: Top swap
    Both of you guys make valid points.
    My money is that this topswap will go horribly wrong. Look forward to his upcoming threads.
    04 Comp G.
  6. #106 Re: Top swap
    Ohio
    Lol at the bunch of ass hattery in here. Look Tim Tim, all you need for the top swap is the hard part.. Blower, heads, lim, balancer, tensioner and idler. I suggest getting a map sensor from an l32 so you can use your stock map plug. Maybe just extend the wiring. Your transmission will be fine as long as you don't **** around like a tard. I'd wait a bit longer and save for everything. Don't do things in steps. Youll waste more money. And get your gaskets from rock auto. A lot cheaper.
    You need to do more research on your own and get off everyone's dick on here. You say you can't find anything, I could put my 13 year old cousin on here and she would find out more than you in an hour and be able to cover all the bases with me.
  7. #107 Re: Top swap
    Dec 2012
    troll land
    What about on here a couple monthes ago?
  8. #108 Re: Top swap
    Dec 2012
    troll land
    Quote Originally Posted by MoarkatsINmuhtrailer View Post
    Hes running a 4t60
  9. #109 Re: Top swap
    Guys.. admittedly Tim is harsh on the car. Track record suggests that while the engine is out, the trans is a wise choice to swap.
    Tim: Your tuner may not be fully up to speed on the differences in the harnesses. Go on your Dad's Alldata and print out the pcm pinouts and trans connector pinouts for the NA and SC GP of your year. Compare and you'll easily be able to add 5 wires/pins and a connector from a JY car into yours plus change over the existing 7 wires. It's straight forward once you look at it.
    Then buy the BCS add on wiring kit from ZZP that also has the map sensor pigtail converter as well. Poof.. there's your wiring differences between the two harnesses.
    Have your tuner do his part on the pcm and you should be in a good place to start it up. Then scan and tune the hell out of it before you ever romp or give it any throttle.
  10. #110 Re: Top swap
    I would not change the harness. That is not hard..but it's harder than adding a few wires.
  11. #111 Re: Top swap
    If what I have posted does not make sense yet.. it's time to search on some of the key terms and read up to get yourself up to speed. Before doing work on a car, you should know the car, the mod, and all the possible issues etc.
  12. #112 Re: Top swap
    Feb 2009
    flintnasty MI
    A l26 intake swap is 300x easier than a 60e to 65e swap... and he managed to do at least 3 major things wrong putting that intake on.
  13. #113 Re: Top swap
    Banned
    Feb 2014
    Grand Blanc/ Flint
    I understand what you are saying. So I need the computer from a gtp, and I need the connector for that computer and wire all of the wires into mine and than the new ones? Or keep my connector and use the open spots for pins to wire in all the new **** for the tranny and have it tuned
  14. #114 Re: Top swap
    Banned
    Feb 2014
    Grand Blanc/ Flint
    I didnt l26 intake swap. I swapped the whole engine.
  15. #115 Re: Top swap
    Banned
    Feb 2014
    Grand Blanc/ Flint
    Im gonna need to find the pinouts. We dont use all data at work so thats not going to work
  16. #116 Re: Top swap
    Banned
    Feb 2014
    Grand Blanc/ Flint
    What if I was to say I can get a 97 gtp harness and computer. Will that just be plug and play?
  17. #117 Re: Top swap
    97 will only work in a 97 car. so if your cars not a 97 forget that pcm.
  18. #118 Re: Top swap
    Banned
    Feb 2014
    Grand Blanc/ Flint
    My car is a 97
  19. #119 Re: Top swap
    one thing in your favor then.
  20. #120 Re: Top swap
    Banned
    Feb 2014
    Grand Blanc/ Flint
    So, just the engine harness is needed and im good
  1. Tuning Issues, 04 GT (L32 Swap / Gear Swap)
    By RivMan in forum PCM Tuning
    Last Post: 09-12-2013, 08:37 PM
  2. Engine swap or top swap
    By 06PONTGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2013, 12:01 AM
  3. l67 swap, trans swap
    By MrPhotographer06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2012, 07:11 AM
  4. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  5. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
