Thread: Supercharger noise - '99 GTP
Results 1 to 20 of 23
  1. #1 Supercharger noise - '99 GTP
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    The S/C sounds pretty noisy. Bearings, I'm assuming? Are there rebuilds available or am I looking at just replacing the bearings? What kind of job is this?
    I had a new coupler put in this a while back and I guess I don't suspect that is making the rattling noise.
  2. #2 Re: Supercharger noise - '99 GTP
    Apr 2012
    Bancroft. Ontario, Canada
    i personally wouldnt bother rebuilding a gen 3 blower (which i'm assuming you have) or pissing around with the bearing's and crap like that...
    i would just get a new blower..... Prime time for a genV (considering they are selling for dirt cheap anymore)
  3. #3 Re: Supercharger noise - '99 GTP
    what coupler did you use? dorman couplers suck and dont last long at all.
  4. #4 Re: Supercharger noise - '99 GTP
    check your oil in the snout before you do anything.
  5. #5 Re: Supercharger noise - '99 GTP
    Feb 2013
    37.295091, -121.930053
    Also ask red to see if he can get one for ya your welcome red lol
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  6. #6 Re: Supercharger noise - '99 GTP
    Apr 2009
    http://intense-racing.com/Merchant2/...3800_Induction
    Above is the coupler I used.
    I checked the oil and it's not overflowing out the plug hole, but it's not so far down that I believe it's been starved. Just below the hole. Does it need to be 100% full for it to not have an ill effect?
    Not worth a rebuilt snout? Intense has them for $150, by the looks of it. Are you suggesting the entire supercharger is bad? I don't know the difference between GenIII and GenV. What goes bad on the remainder of the S/C? I thought just the snout could lose bearings.
    Red? I searched the username "red" and he's never had a post here. Is this the right member? I assume it is not.
  7. #7 Re: Supercharger noise - '99 GTP
    Fill the oil to the top off the hole and see if the noise goes away
  8. #8 Re: Supercharger noise - '99 GTP
    Apr 2012
    Quote Originally Posted by SnowDrift View Post
    For $150, you can buy a full Gen3 blower lol
    for $175-$300 or so. you can buy a full gen V
    GenV is a more efficient blower... There's a few thread's here about the key differences between the two
  9. #9 Re: Supercharger noise - '99 GTP
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    I believe 'red' is 'redcompg'
  10. #10 Re: Supercharger noise - '99 GTP
    Apr 2009
    Quote Originally Posted by tomtom123 View Post
    Thanks. Sent a PM
  11. #11 Re: Supercharger noise - '99 GTP
    There are bearings on the shaft in the snout. Then two bearings in the centre section that holds the rotors in place. Finally there are two more in the case itself at the other end of the rotors.
    The two in the centre are not replaceable. There is an aussie who went through the trouble of replacing them, but you might as well buy a new rotor pack at that point. The snout ones require a press, and the case bearings need to have holes drilled and tapped behind them and pressed out with grease.
  12. #12 Re: Supercharger noise - '99 GTP
    Jun 2014
    Destin, FL
    I had the same issue right after I got my GTP and it ended up being the rear rotor bearings. here is a pic to give you an idea where they are
    to get them out you have to drill and tap 2 holes at the bottom side of the supercharger case for 1/8'' npt, then use a grease gun to push them out. here is a pic of the holes.
    then of course you have to clean up and press new ones.
  13. #13 Re: Supercharger noise - '99 GTP
    Apr 2009
    Pretty sure it's the snout bearings. I took it off last night and the bearings sound dry. Is there any sealer that goes between the plate behind the snout between this plate (holds the one end of the screws) and the S/C case?
  14. #14 Re: Supercharger noise - '99 GTP
    Jun 2014
    Destin, FL
    Yes you use a very thin coat of gasket maker/rtv between the snout housing and the rotor pack plate. the snout is easy to rebuild if you have access to a press.
  15. #15 Re: Supercharger noise - '99 GTP
    Apr 2009
    Quote Originally Posted by sagillman View Post
    I mean is there anything between the rotor pack plate and the S/C case?
    Probably should press the bearings out myself, but I don't have a puller for the pulley. Does the puller HAVE to be a S/C pulley puller, or can another type be adapted to work? If I recall correctly, the last time, it came off fine when the guy at INTENSE took it off.
  16. #16 Re: Supercharger noise - '99 GTP
    Jun 2014
    Destin, FL
    As far as I know there is no sealant between the plate and the main housing. if you have access to a press and your rebuilding the snout you don't need the puller, just remove the pulley bolt, and press the snout shaft out through the housing. once that happens the pulley should fall right off as soon as you release the pressure on the press. I have rebuilt many rear ends and manual transmissions so none of this was very difficult for me. here are a couple of videos I used for a reference.
    http://www.youtube.com/watch?v=m7lYCuj4w2Q
    http://www.youtube.com/watch?v=I1H47_d4JTI
    these are not my videos just to be clear.
  17. #17 Re: Supercharger noise - '99 GTP
    Apr 2009
    Ok, you talked me into it. I cancelled the shipment and will just do this myself. Thanks for the great video links. Those make it look very reasonable to do myself.
    I'm using the stock pulley - how far do I press it back onto the shaft? Does it only go so far? Press until the pulley is flush with the end of the shaft, I assume.
  18. #18 Re: Supercharger noise - '99 GTP
    Jun 2014
    Destin, FL
    yep, when I was pressing the pulley back on I released pressure on the press 2-3 times to check my progress, I didn't want to go to far. It wasn't very hard to do this, hell it took longer to clean everything out then it took to press the bearings on or off.
  19. #19 Re: Supercharger noise - '99 GTP
    Apr 2009
    I got this all apart last night by pressing everything out myself. My question is about the shaft. It was protruding past the end plate about 1/8" or so. When I reinstall, should it be exactly flush?
    On edit, I watched the part 2 video and he mentions that some shafts will protrude, but all the parts back up against a shoulder.
  20. #20 Re: Supercharger noise - '99 GTP
    Apr 2009
    Down toward the bottom of this link, there is a photo of the sealer on the flange. Is this right on how it should look before reassembly?
    http://www.3800supercharger.net/nosedrive.html
  1. Supercharger noise?
    By mick777wauchope in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-08-2012, 09:29 PM
  2. supercharger noise
    By thomas mcnulty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-01-2012, 04:51 PM
  3. Supercharger Noise
    By Jbruce in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2012, 09:41 PM
  4. supercharger noise
    By sdenton8 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2010, 06:04 PM
  5. Supercharger Noise
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2009, 03:45 PM
