look for the other side of the taped off line. if need be you can slide a new rubber vac line over the hard line and make the connection. your boost wont show cause the map sensor is not seeing any vacuum. car must be running like crap with a leak like that.
follow the diagram posted up there and make sure its all plumbed back right. should be a night and day difference.
if you get the taped off line reconnected to its other 1/2 your a/c and heat will work like it should. like i said earlier, look under the fuse box on the pass side wheel well for the other side, its a hard line like up top where its capped.
