Thread: 42# injectors for an '04
Page 1 of 3 123 LastLast
Results 1 to 20 of 46
  1. #1 42# injectors for an '04
    Slower, Lower Delaware
    I searched and read all I could find on injectors for an '04 GTP but I would still like the opinion of some people that have them. I have 1.9 rockers, a PLOG, a 3" catted down pipe, A S2IC from ZZP, and a 3.4 pulley. What brand of injector seems to work best for our cars.
    TIA
  2. #2 Re: 42# injectors for an '04
    Feb 2009
    flintnasty MI
    Shouldnt need to upgrade unless you really want to add more mods.
  3. #3 Re: 42# injectors for an '04
    Feb 2009
    flintnasty MI
    If you do I always suggest the 39# mustang injectors. They flow a bit higher than 39 usually and are a cheap direct drop in.
  4. #4 Re: 42# injectors for an '04
    I'm planning for a little more modding.
  5. #5 Re: 42# injectors for an '04
    Oct 2011
    Puyallup WA
    As dh just said cobra 39lb are a great option cheap easy to find and ev6...39lb is at 40psi so they are actually 42lb ish at 43.5psi...bought a low miles set this morning off eBay for $137
    08 G8 GT - exhaust Tune
  6. #6 Re: 42# injectors for an '04
    I bought 42.5# with the adapters for my car
  7. #7 Re: 42# injectors for an '04
    Is one brand better than the others?
  8. #8 Re: 42# injectors for an '04
    It's all about the same from what I've heard. I'm running lucas
  9. #9 Re: 42# injectors for an '04
    GT Level Member Overkill's Avatar
    Nanaimo British Columbia
    I have 44# GM injectors available plus a MAF upgrade, both which you'll need beyond a 3.4.
    Email all inquiries to willoverkill@gmail.com!
  10. #10 Re: 42# injectors for an '04
    Quote Originally Posted by Overkill View Post
    I'll email you.
  11. #11 Re: 42# injectors for an '04
    Why do you need a maf upgrade? I'm on a 3.2 on stock maf.
  12. #12 Re: 42# injectors for an '04
    Feb 2009
    flintnasty MI
    A 3.2 and a stock 04 maf are good on stock injectors on a 04.
  13. #13 Re: 42# injectors for an '04
    DSMUTS, Yeah, everyone is telling me I need a MAF upgrade or a PCM upgrade. Did you get your PCM tuned for the 42#s?
    Dark, DSMUTS is on 42.5# injectors.
  14. #14 Re: 42# injectors for an '04
    Yeah you need tuned for injectors
  15. #15 Re: 42# injectors for an '04
    Pennsylvania, USA
    Maybe get a fuel pump rewire too while you're at it? Casper seems to be a good brand.
  16. #16 Re: 42# injectors for an '04
    Quote Originally Posted by nik12937 View Post
    Is there a fuel pump rewire made for '04+ GPs?
    Sorry, found one.
  17. #17 Re: 42# injectors for an '04
    Pennsylvania, USA
    I was gonna say, I thought it was the same or at least very similar Just a pain not having an access panel to the fuel pump right in the trunk.
    For thine is the Cam, The Piston, and The Rod, Forever and ever (or until they break). Amen.
  18. #18 Re: 42# injectors for an '04
    04- some 05 have that access panel
  19. #19 Re: 42# injectors for an '04
    Racetronix makes a rewire that plugs in underneath the vehicle by the gas tank for 05+ with no access panel. Still has the small wiring between that connector and the pump but at least it replaces everything else.
  20. #20 Re: 42# injectors for an '04
    Overkill, Working out some prices on those 44#s and the tune I need?
  1. ZZP 42.5 lb Injectors
    By SgtMarshal in forum For Sale - Parts
    Last Post: 11-21-2013, 06:44 PM
  2. 42.5# injectors
    By Nyc93 in forum For Sale - Parts
    Last Post: 10-24-2013, 11:59 AM
  3. Injectors
    By saleenprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2010, 03:47 PM
  4. l67 injectors
    By nascartech in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-08-2010, 08:56 PM
