tomtom123
So I have been searching for the past couple of days and can't seem to find where I am leaking oil from.
99 GTP just did an engine swap and replaced all of the gaskets from the top to the bottom. Including timing cover and oil neck gaskets.
The oil appears to be leaking somewhere close to the power steering pulley when the car is running. Its hard to see where the leak is originating so I am kind of wondering if there are any common leakage areas that anyone knows of in this area?
I put the tack seal stuff on with the timing cover gasket so I'm fairly sure this isn't where the leak is. But again, I'm not ruling anything out yet either. Thanks in advance
Sent from my SM-N900P using Tapatalk
