Thread: What plugs should i use?
Results 1 to 15 of 15
  1. #1 What plugs should i use?
    Aug 2008
    kansas
    im just wonderin wht plugs i should use. I have a cai, ubend delete, 3 in dp, 180 tstat, and msd coils and wires ready to go when i decide on plugs. Any suggestions would be great!!!
  2. #2 Re: What plugs should i use?
    SE Level Member TehGTP's Avatar
    May 2008
    Saint Louis, MO
    sell the MSD coils.
    as far as what plugs, my lawn mower uses Bosch plugs. but thats a lawn mower.
    /sarcasm
    but seriously we need a few more pertinent details such as.. are you supercharged?
    2007 Corvette Z06 - BFD Cam / E85 / milled & fixed heads
    2006 GTO M6 18's - SOLD - VRX5 Cam | FAST 102 | Exhaust
    2001 GTP - SOLD - 1.9 | TOG's | E85 | LC1 | B+G | AGX | GMPP | 3EP
  3. #3 Re: What plugs should i use?
    Aug 2008
    kansas
    sorry.. yea 2002 gtp.. sell the coils? are they not worth it?
  4. #4 Re: What plugs should i use?
    Aug 2008
    kansas
    i was thinkin id get tr55 plugs... does that sound about right for what i have done?
  5. #5 Re: What plugs should i use?
    May 2008
    Saint Louis, MO
    those should work, as long as you use a copper plug.
    i personaly have not used any NGK's yet in my grand prix.
    ive stuck with autolites and they work fine for me.
    i ran the AL605's on stock pulley then went to AL104's w/ the 3.4
    the MSD coils should be used for cosmetic reason only.
    the stock coils are more than up to the task.
    mine are still stock at 135k - no issues so far here.
  6. #6 Re: What plugs should i use?
    Aug 2008
    kansas
    thanks alot!! Youve been alot of help!
  7. #7 Re: What plugs should i use?
    id say go for some stock replacements or the like unless you are going to be dropping pullies. you really want to keep the spark as hot as possible until you start making more boost where you have to start dropping heat ranges.
  8. #8 Re: What plugs should i use?
    Apr 2008
    Chillin at the Beach , VA
    I'm running the NGK TR55IX plugs, MSD 8.5mm wires and MSD coils. Haven't had any problems as of yet.
  9. #9 Re: What plugs should i use?
    Aug 2008
    kansas
    whats the difference between the tr55 and the tr55ix
  10. #10 Re: What plugs should i use?
    Hoffman/Schaumburg, IL
    ix is iridium, smaller tip, better material, but about 3x the price of copper, I run TR6ix
  11. #11 Re: What plugs should i use?
    Aug 2008
    KCMO
    im thinking about putting in some tr55ix pluggs and the tdcracing intake in my car its an 06 gt s/c. will that be ok for my car?
  12. #12 Re: What plugs should i use?
    Aug 2008
    kansas
    id like to help but i have no idea.. but from what ive been told that sounds about right
  13. #13 Re: What plugs should i use?
    May 2008
    Saint Louis, MO
    go for it man. you r car wont blow up if that answers your question.
  14. #14 Re: What plugs should i use?
    Topeka, KS
    MSD coils are a waste of money imo. Our cars came with NGK's or at least mine did. If you go autolites I would go 605's with your mods and as your mods progress 104's then 103's. Sorry I'm not much help with the NGK's although I would like to run them again.
  15. #15 Re: What plugs should i use?
    Aug 2008
    KCMO
    so i swapped my plugs to the NGK TR55IX's amazing how much it woke my car up. ordering the TDC intake in a couple of days and thought about doing a pcm tune will i have to worry about having to scan my car for KR?
  1. AC Delco plugs
    By jak2908 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-10-2008, 03:08 PM
  2. plugs?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2008, 12:32 PM
  3. TRI-55X Plugs=bad KR for my car?
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-25-2008, 04:44 PM
  4. Plugs???
    By crashman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2008, 10:00 PM
