Thread: Bad PCM?
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Bad PCM?
    SE Level Member Daven's Avatar
    Apr 2014
    Saskatchewan, Canada
    Would leaving my ground bare for a couple inches be bad? I couldn't see it touching any bare power sources there. But the black tape did melt a bit like I figured. So If I need it insulated, I'm not sure what to do
    Using Tapatalk
  2. #22 Re: Bad PCM?
    SE Level Member transam24's Avatar
    Dec 2011
    NY
    Put some heat shrink tubing over the exposed wire or else your going to have some serious corrosion problems
  3. #23 Re: Bad PCM?
    Why did you cut the insulation so much. That's a huge exposure. It'll throw some heat shrink over it.
    04 Comp G.
  4. #24 Re: Bad PCM?
    Apr 2014
    I have the slack and wanted to try insulating it differently to see it that melted too. It did start to so I took it off again. Either way putting it back how it was isn't going to help any. I'm going to hunt around for heat shrink for this size wire and see what I can figure out
    Using Tapatalk
  5. #25 Re: Bad PCM?
    It's a ground.. so what if it doesn't have insulation. Looks like he'll be changing it before it ever has a chance to corrode and screw up,
  6. #26 Re: Bad PCM?
    being the insulation is that wide open it will get dry wire and stop being a good cable in 4 to 6 months easy. bare metal is never good for the long haul.
  7. #27 Re: Bad PCM?
    True.. and what I'm saying.. I feel still applies.
    Stock cable.. it works like a champ until you replace it with a fresh cable.
  8. #28 Re: Bad PCM?
    Jun 2021
    Bad ground or bad body control module would be my guess.. scan the bcm and see what the ignition 1 voltage says when your issues arise.. if the voltage drops then I would suggest going thru all the bcm power wires and grounds
