All three system lights come on now at the same exact time. Used to happen once in a great while, now it's very common. Is it just an abs sensor? If so how much would a fix be?
Yep, probably ABS sensor. Need a whole new bearing. Less then $100 but you gotta find out which one it is.
Find a local shop that can scan for abs codes and pay a few bucks and let them scan it and tell you what's wrong. Saves you plenty of time as well as having to play the guessing game. Oh and saves you from replacing parts that may not be the fix.
I haven't had is scanned yet and I plan to soon, but I notice that the abs light comes on and the TC and Stability control turns off when I turn the wheel sharply... didn't know if that changes anything
Sent from my SAMSUNG-SGH-I337 using Tapatalk
all 3 will come on at the same time as they all need common wss data for proper operation. when a fault is detected, all 3 system are disabled. turning the wheel flexes the front wss harness at the control arms, possibly causing a signal drop out.
My old man's buick had the same issue, somebody forgot to make sure the connector "snapped" when pushing it in, contact cleaner (from dirty contacts of being unplugged and driven) and a "snap" and it was good to go
Sometimes before the systems turn off the abs stays on and when I go to brake regularly the abs kicks on like it senses wheel slip
The wheel sensor wires leading to the abs computer break about 6in from the plug, usually where the wires sit on top of the control arm. They make a repair kit for it.. I had to replace both fronts on my car
I sure did.. I still own a few of these cars and I'm sure others do to so while looking around I figured why not put the fixes on a few that didn't have any
