Thread: How long should fuel pressure hold with koeo
Results 1 to 10 of 10
  1. #1 How long should fuel pressure hold with koeo
    Aug 2013
    Kitimat, B.C.
    Mine goes from 42ish down to zero in just under a minute. Not sure if something's wrong with the pump or not.
    86 Fiero se convertible 3800sc 4t65e HD(2002), Gen V, 3.3 pulley, SD headers
  2. #2 Re: How long should fuel pressure hold with koeo
    It shouldn't bleed down that quickly.
  3. #3 Re: How long should fuel pressure hold with koeo
    Aug 2013
    Kitimat, B.C.
    It keeps up at idle and goes up with a manual rev of the throttle. So I assume it's keeping up at wot. It's an aftermarket race pump, 300lph.
  4. #4 Re: How long should fuel pressure hold with koeo
    FSM says after you have bled out the gauge, that it should hold for 10 min
  5. #5 Re: How long should fuel pressure hold with koeo
    Aug 2013
    Kitimat, B.C.
    How are you supposed to tell if it's holding pressure if there's no guage attached?
  6. #6 Re: How long should fuel pressure hold with koeo
    Quote Originally Posted by tweeder View Post
    You attach one. If you are looking at pressure, then you must have something to look at the pressure with..aka a gauge.
  7. #7 Re: How long should fuel pressure hold with koeo
    Aug 2013
    Kitimat, B.C.
    Oh, i have a guage permanently mounted at the shrader valve.
  8. #8 Re: How long should fuel pressure hold with koeo
    Aug 2013
    Kitimat, B.C.
    i forgot to mention that it has a new fuel pressure regulator. I also have the pump assembly out and in a bucket of fuel, how do i test it and what am i looking for?
  9. #9 Re: How long should fuel pressure hold with koeo
    hangover park IL
    i have yet to see a high flow aftermarket pump with the anti bleedback valve blocking/restricting that tiny ass fuel feed nipple.
    1 minute bleed down is quite good for not having the oem checkvalve (which is the only way the system will hold pressure longer than a minute...)
    the cure is a change in your starting tactic/training yerself.
    key on, pause for 1-1.5seconds (as the pump nears the end of prime, then start cranking either after its stopped priming, or before if you get really good at it (might as well save yer FP relay some wear and tear)
    you get used to it.
    or you can kneecap your sweet high flow pump down to 180lph by reinstalling the factory checkvalve.
    id compromise on the startup sequence...
    in short...your fine as long at KOEO yer FP is 48-52 ish or ~58ish on the deadhead fuel system cars (04+)
    ~James~ Psychotic Gearhead
  10. #10 Re: How long should fuel pressure hold with koeo
    Aug 2013
    Kitimat, B.C.
    Quote Originally Posted by Turbocharged400sbc View Post
    you get used to it.
    Ok thats good to know, thanks. I have no problem starting as soon as i turn the key
  1. Replies: 19
    Last Post: 10-20-2015, 09:22 PM
  2. 4T65E: How long will it hold up?
    By DanielGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-27-2012, 09:13 PM
  3. Fuel pressure won't hold...
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2011, 10:10 PM
  4. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
