Thread: rockers cam combo
Results 1 to 20 of 20
  1. #1 rockers cam combo
    Sep 2013
    Massachusetts north shore
    Has anyone done a custom cam and 1.9 combo
  2. #2 Re: rockers cam combo
    You'd have to do some crazy work on the heads and even then I don't know if it's possible.
  3. #3 Re: rockers cam combo
    The Boss Iceman6669's Avatar
    Jun 2011
    You would have to do the math and figure out what the lift ends up being on the cam + rockers and make sure your valve guides can allow it.
    2011 F-150 Yote powered
  4. #4 Re: rockers cam combo
    Sep 2013
    I am a little disappointed with the yt 1.9 and 105 spring upgrade i feel like i lost a lot of low end torque and shifted a little up top i does feel like a more constant and longer powerband but i was looking for more i didn't want to take them out but my lifters are a little noise and need replacement while i am in there i was going to do single roller master chain and tensioner thats why i was looking for a cam that is slightly more aggressive than stock with a little more lift and duration
  5. #5 Re: rockers cam combo
    Jun 2011
    To my knowledge(and I might be wrong) all cams would require head work with 1.9s.
  6. #6 Re: rockers cam combo
    Sep 2013
    Would that be to run a stage 1 / vs cam or if i were to go threw comp with a custom cam with equal lift on 1.9 rockers
  7. #7 Re: rockers cam combo
    Jun 2011
    ANY cam + 1.9s will require head work.
  8. #8 Re: rockers cam combo
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Shocked that you weren't happy with the 1.9's.....always a great simple upgrade IMO.
    Like Josh said...there isn't a cam out there on the market that you can run 1.9's with. Running a combination of both is extremely costly. Sell the 1.9's and use funds to buy a bigger cam.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  9. #9 Re: rockers cam combo
    Feb 2009
    flintnasty MI
    You could run a VS or NIC on 1.9 rollers... would still probably be a downgrade over stock.
  10. #10 Re: rockers cam combo
    Jun 2011
    On stock heads?
  11. #11 Re: rockers cam combo
    Sep 2013
    Thanks for your opinion guys i think ill do the chain lifters and intercooler i have a ported gen 3 and lim with headers 3.4 pulley and all the proper mods to go with it but still about 7 degrees of kr that has gone down some with tuning i dont want to take out timing to do so whats my best next mod to reduce it
  12. #12 Re: rockers cam combo
    Nov 2011
    NY
    Quote Originally Posted by fbm View Post
    May I ask why you are asking?
    Plans for engine, lift desired? Have you considered all the angles in wanting the high ratio rockers? Do you plan modded or roller rockers?
  13. #13 Re: rockers cam combo
    hangover park IL
    I built a full boogie VS with 1.7's on IS3 heads... was pretty sweet on a turbo monte
    ~James~ Psychotic Gearhead
  14. #14 Re: rockers cam combo
    Nov 2011
    NY
    There is actually an old Comp Cam grind with .285 lift that will result in .542 with the 1.9's... I just asked the same question of some folks here that have been there & done that. But as mentioned, without head work there is little benefit (flow) and problematic (clearance) to go this route. It is why I asked your intentions previously.
    Go BIG or go home right! Hehehe... : )
    But you've gotta have a plan. And big lift should be planned right. Subsequently, after doing some research, I decided against using the 1.9's I have with that cam and will instead be going a different route with 1.7 YT Rolling Rockers...
    Big breathing is not just for turbo as some would have it, but I guess I'm just old school, want biggest intake with biggest exhaust, lol.
    These are all my opinion of course : )
  15. #15 Re: rockers cam combo
    hangover park IL
    the more overlap you have (nearly unavoidable at huge lifts) the more bleedby and more headaches with closed loop tuning...to the point hwere your stuck open loop with only trial and error tuning and limited automatic adjustment to fueling.
    and when your talkin about cams...tons of folks run the st5 cam yet we made more power than 90% of them with a tiny duration little st1r
    once you go over 550 lift your just wearing the guides faster unless you open up the heads.
    you can only shove so much **** through a low flow toilet
  16. #16 Re: rockers cam combo
    Feb 2009
    flintnasty MI
    Quote Originally Posted by Iceman6669 View Post
    On stock heads?
    Nic 1.8s stock heads was easy. 1.9s wouldn't be much different.
  17. #17 Re: rockers cam combo
    Nov 2011
    NY
    NIC = .317 lift x 1.9 = .602 lift on stock heads?
    Please explain how this works, absent any detrimental effect. Thanks.
  18. #18 Re: rockers cam combo
    Feb 2009
    flintnasty MI
    Same way a 1.75ish stock rocker lives on top of XP cam... its just smashing the valve seals a bit.
  19. #19 Re: rockers cam combo
    hangover park IL
    it's not hard to put a straight edge across the valve cover rails and hit the top of your guides with a grinder to take off a tenth of an inch
  20. #20 Re: rockers cam combo
    Jun 2011
    Or just do it right ...
    http://youtu.be/KQcil-iv_4w
  1. 04+ Best Exhaust combo
    By crzystve42 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2012, 09:05 AM
  2. amp & sub combo... capacitor?
    By GTPjunkie in forum Audio, Security & Visual Electronics
    Last Post: 03-06-2010, 10:49 AM
  3. Will this combo work for mid 13's??
    By TDCRacing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-29-2008, 08:40 AM
