Thread: Misfiring after 100mph!
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 97
  1. #1 Misfiring after 100mph!
    GT Level Member ricio1991's Avatar
    Feb 2014
    Tempe
    Okay guys i have a 2004 grand prix gtp competition package and it has 102k miles. Got the car checked out by a shop because of a random misfire after like 100mph or more. Only on freeway in the streets its fine no codes thrown or anything. Mechanic said start with a transmission fluid replacement and see from there and still charged me not answering why it was misfiring. He said everything looked good. What should i do. I changed the fluid in the transmission 2 weeks ago at another shop. Car runs great until 100 and more! Please help I'm tired of paying mechanics for no answers!
    I was thinking of taking it to gm
  2. #2 Re: Misfiring after 100mph!
    Feb 2014
    Tempe
    Plugs fuel filter etc done. Tune up done! I cant think of anything else.
  3. #3 Re: Misfiring after 100mph!
    At exactly 100? Does the check engine light flash?
  4. #4 Re: Misfiring after 100mph!
    Feb 2014
    Tempe
    Yes its on and off. Yesterday was driving down the freeway. One pull i did full throttle and around 100ish it started flashing. So i let go off the gas because i don't want to damage anything. So i wanted to see it again to try to figure out if it happening constinetely and i did a pull to 110mph and no flashing. So it really weird
  5. #5 Re: Misfiring after 100mph!
    St. Louis
    What kind of plugs did you install? Also, did you reuse the old wires? The flashing is showing a possible catalyst damaging misfire as you seem to know.
  6. #6 Re: Misfiring after 100mph!
    Feb 2014
    Tempe
    Thats doesn't sound good! I already have changed the catalytic converter i got warranty but still would suck to pay labor again. New bosh wires with ngk i believe.
  7. #7 Re: Misfiring after 100mph!
    Feb 2014
    Tempe
    Its been about 10k miles since i did the wires and plugs. I did the catalytic converter also with 02 sensor. Why would it happen only at high speed possibly overdrive
  8. #8 Re: Misfiring after 100mph!
    Mar 2012
    NC
    Does it happen while cruising or WOT? By the sound of it, you're WOT 3rd gear...lots of load...probably around 4000RPM...
  9. #9 Re: Misfiring after 100mph!
    Feb 2014
    Tempe
    Correct! It only happens at wot high speeds! But not at low speeds. I can full throttle from a dig and go and no problem
  10. #10 Re: Misfiring after 100mph!
    Feb 2013
    37.295091, -121.930053
    you don't need to be going that fast. more stuff will break like your transmission, engine, etc.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  11. #11 Re: Misfiring after 100mph!
    Mar 2012
    NC
    It's the load...possibly MAP/MAF related. I'd love to see freeze frame data on it.
  12. #12 Re: Misfiring after 100mph!
    Feb 2014
    Tempe
    I know i don't but i want to fix the problem or just fix it. Im just trying to conclude wether i should get rid of it or not. Cus if its serious i don't want to deal with it. But yes i understand but these cars are pretty strong they shouldn't have a problem at 100mph. I wish it was running 100 percent
  13. #13 Re: Misfiring after 100mph!
    Feb 2014
    Tempe
    Thanks whats freeze frame data? I may get a second opinion by a gm mechanic here in my city hes very familiar with gm cars
  14. #14 Re: Misfiring after 100mph!
    Feb 2013
    Quote Originally Posted by ricio1991 View Post
    understatement of the year for these gp's
  15. #15 Re: Misfiring after 100mph!
    Feb 2014
    Tempe
    Yeah i already put in like 2k of mechanic work in the last year and a half!!!
  16. #16 Re: Misfiring after 100mph!
    You're Probably getting a ton of kr and the motor hates it. You'd need to scan for kr and see what you're getting
  17. #17 Re: Misfiring after 100mph!
    Feb 2014
    Tempe
    Cool. Ill have to look into that! Definitely sounds like kr
  18. #18 Re: Misfiring after 100mph!
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Keep doing 100mph and youll be spending at least that much every year.
    I went NA when a whore left -$300 in my bank account.
  19. #19 Re: Misfiring after 100mph!
    Life lessons ehh
    04 Comp G.
  20. #20 Re: Misfiring after 100mph!
    Feb 2014
    Tempe
    I wont be doing pulls until i find out exactly issue and fix it. Ill see thanks for the information tho
  1. 05 Misfiring
    By PontiacL32 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2012, 11:34 PM
  2. Misfiring
    By panheadred in forum General Tech Discussion
    Last Post: 04-25-2012, 11:16 PM
  3. Misfiring HELP!!!!
    By Grandprix07gt in forum General Tech Discussion
    Last Post: 03-07-2011, 04:17 PM
  4. misfiring
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-20-2010, 09:22 PM
  5. 24 MPG while averaging 100MPH!!!! Not too bad.
    By Morris 04 GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2008, 07:28 AM
