Thread: Maf code now I have a vac leak coming from my intake
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #21 Re: Maf code now I have a vac leak coming from my intake
    Banned
    Jan 2013
    maryland
    Anybody?
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  2. #22 Re: Maf code now I have a vac leak coming from my intake
    gardner,mass
    Quote Originally Posted by Adecker View Post
    use brake cleaner on the maf
    I loled
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  3. #23 Re: Maf code now I have a vac leak coming from my intake
    Banned
    Jan 2013
    maryland
    Again lol anybody?
  4. #24 Re: Maf code now I have a vac leak coming from my intake
    Mar 2012
    NC
    If you're going to splice, do it proper and solder it in with shrink tube to cover it. It'll be a much more stable repair.
  5. #25 Re: Maf code now I have a vac leak coming from my intake
    Banned
    Jan 2013
    maryland
    Thanks do you know if the 03 maf harness is different from the 97 n af connection thats my biggest concern
  6. #26 Re: Maf code now I have a vac leak coming from my intake
    Mar 2012
    NC
    It's the same...do it to it.
  7. #27 Re: Maf code now I have a vac leak coming from my intake
    Mar 2012
    NC
    EDIT: It SHOULD be the same. LOL
  8. #28 Re: Maf code now I have a vac leak coming from my intake
    Banned
    Jan 2013
    maryland
    I'll take your word for it lol any way to check for ground and power in the maf harness? Could I use my tester while the car is on and check my maf harness?
  9. #29 Re: Maf code now I have a vac leak coming from my intake
    Mar 2012
    NC
    You should be able to if you have a DMM and a wiring diagram.
  10. #30 Re: Maf code now I have a vac leak coming from my intake
    Banned
    Jan 2013
    maryland
    Dmm? Corrected digital multimeter
  11. #31 Re: Maf code now I have a vac leak coming from my intake
    Mar 2012
    NC
    Yes. Sometimes it is also referred to as a DVOM: Digital Volt Ohm Meter
  12. #32 Re: Maf code now I have a vac leak coming from my intake
    Banned
    Jan 2013
    maryland
    Ok so sven I check ground and signal correct?
  13. #33 Re: Maf code now I have a vac leak coming from my intake
    Mar 2012
    NC
    You'll check all three wires...one should be a ground, a reference voltage, and a signal. I can't remember if the MAF gets 12v from the battery or 5v from the computer.
  14. #34 Re: Maf code now I have a vac leak coming from my intake
    Banned
    Jan 2013
    maryland
    Ok i'll check all connections could I use spray like battery cleaner of some sort on the wires?
  15. #35 Re: Maf code now I have a vac leak coming from my intake
    Banned
    Jan 2013
    maryland
    Could my Tps make my maf code come? I did a test with my maf and everything is fine with my connections but my tps harness power slowly fades thru my dmm and I checked also with a 12 6v volt tester I have should I replace that harness with a new one? I have a extra tps harness laying around
  16. #36 Re: Maf code now I have a vac leak coming from my intake
    Banned
    Jan 2013
    maryland
    Well?
  1. Cant pinpoint where my coolant leak is coming from ??
    By thegipper in forum General Tech Discussion
    Last Post: 04-20-2013, 02:48 PM
  2. Don't know where my coolant leak is coming from?
    By sseigtp in forum General Grand Prix Discussion
    Last Post: 08-17-2012, 01:59 PM
  3. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  4. cant figure out where this leak is coming from.
    By Drews in forum General Tech Discussion
    Last Post: 03-22-2012, 04:48 PM
  5. I have an antifreeze leak coming from the intake
    By lzicc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-19-2010, 01:36 PM
