Thread: Battery and fusebox relocation
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
  1. #21 Re: Battery and fusebox relocation
    GT Level Member m17davis's Avatar
    Orland Park, IL
    Yes you can just run a positive and negative from the trunk to the bay. But you need a distribution block. So it can go from that too the starter and alternator. REDCOMP made it perfectly clear above for a write up Conner
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  2. #22 Re: Battery and fusebox relocation
    hangover park IL
    anything over 2 ga for the starting/charging is just extra dead weight.
    the Riv had a little voltage drop under startup with 4ga (your highest current draw, ive measured 120-180 amps depending on the starter) with 2 gauge replacement (welding cable) voltage drop was under 0.2 for only a fraction of a second durring startup, lights stronger.
    starter sound/startup didnt change much, so the racing guys are probably happier with the lower weight of the 4ga.
    then again since the weight is being moved to the rear of the chassis where its not desired..... im sure no one cares about an extra 30+ lbs of copper slowing em down too
    ~James~ Psychotic Gearhead
  1. trouble shooting trunk release, found sensors behind fusebox..?
    By vegasridercc in forum General Grand Prix Discussion
    Last Post: 09-21-2012, 10:42 AM
  2. Engine fusebox wires melted
    By Bluemagic in forum General Tech Discussion
    Last Post: 09-08-2012, 03:46 PM
  3. new fusebox cover and cross braces
    By beckys2000gt in forum Visual/Body Modifications
    Last Post: 06-26-2010, 10:12 AM
  4. Custom Fusebox & Underhood Lining
    By Spartan GL in forum Visual/Body Modifications
    Last Post: 01-20-2010, 12:16 AM
  5. Battery relocation question - windshield washer tank
    By roboz in forum General Tech Discussion
    Last Post: 07-11-2009, 02:51 AM
