Thread: coolant leak
Results 1 to 18 of 18
  1. #1 coolant leak
    SE Level Member Snoop dogg's Avatar
    Dec 2013
    chicago
    hey guys i have a 98 grand prix GTP and i notice i have coolant leaking from some where on the passenger side of the motor but can not find it any ideas
    ....::::THE DREAMER::::....
  2. #2 Re: coolant leak
    Coolant elbows or water pump
    04 Comp G.
  3. #3 Re: coolant leak
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Coolant Elbows, Water Pump, Heater Hoses being some possible suspects.
    2012 F150 STX
    - Gonna be a race truck
  4. #4 Re: coolant leak
    Dec 2013
    chicago
    so if it is the elbows what kind of new elbows should i go with
  5. #5 Re: coolant leak
    Dorman aluminum ones
    04 Comp G.
  6. #6 Re: coolant leak
    Dec 2013
    chicago
    okok any thing else i should do while im changing the elbows
  7. #7 Re: coolant leak
    Apr 2012
    Dayton, OH
    Dorman #47065hp
    RED YOU TOO FAST
    2012 F150 STX
  8. #8 Re: coolant leak
    Dec 2013
    chicago
    should i do LIM while im at it
  9. #9 Re: coolant leak
    Hmmm depends has it been done yet? If you already have the metal lim gasket then no need to do it but if you still have the plastic ones you can go ahead and do them if you like.
    04 Comp G.
  10. #10 Re: coolant leak
    Dec 2013
    chicago
    well i notice if i take the oil cap off while the car is on the car change in idle is this normal
  11. #11 Re: coolant leak
    Dec 2013
    chicago
    and i do think any thing has been changed on the car before i bought it
  12. #12 coolant leak
    Take a look at where the lim meets the head.. You can see if it's aluminum (silver) or plastic it'll be black. If it's plastic now would be a good time to change it
    04 Comp G.
  13. #13 Re: coolant leak
    Dec 2013
    chicago
    yeah there plastic any thing else i should do
  14. #14 Re: coolant leak
    Huge camshaft, and turbo!!
    04 Comp G.
  15. #15 Re: coolant leak
    And you can do the Valve covers gaskets if they are old just to be safe besides that... Elbow, lim and vc gasket you'll be good to go
    04 Comp G.
  16. #16 Re: coolant leak
    Dec 2013
    chicago
    good looking RED thankz
  17. #17 Re: coolant leak
    Dec 2013
    chicago
    the coolant is leaking from the elbows i guess the rings are bad they seem to leak when im going above 70mpr
  18. #18 Re: coolant leak
    Dec 2013
    chicago
    funny dont want to go that fast as of yet might f**k some S**t up the car is still stock for now
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  3. Need help..coolant leak
    By Ktrap in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2011, 11:20 AM
  4. coolant leak
    By NR92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2011, 11:56 PM
  5. Coolant leak fix.
    By Rcrevolution in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2010, 11:57 PM
