Thread: 3800 Engine Swap -- will not start -- HELP
Results 1 to 5 of 5
  1. #1 3800 Engine Swap -- will not start -- HELP
    Dec 2013
    salisbury md
    I have a 2004 Grand Prix GPT. Engine,auto-trans, complete with harness, PCM, body control module, etc., installed ina Lambo kit.
    When I turn the key on, cluster lights up, no warnings on display, except ABS andtraction control which are not being used. When
    I turn key to start, cluster goes dark, fuel pump does not run, engine does not crank.
    Italmost seems like trying to start in gear. Anyone know how Auto-trans neutral switch works?
    OBDcode reader will not make connection to PCM. I have Alldata wiring diagrams, but, boy are they complicated! Any hints where to starttrouble-shooting? Don't want to haul itto a dealer.
  2. #2 Re: 3800 Engine Swap -- will not start -- HELP
    HUDSON
    Nuetral safety switch is a good place to start.
  3. #3 Re: 3800 Engine Swap -- will not start -- HELP
    St. Louis
    Check the fuse for the cig lighter. This is tied to the OBD port IIRC. When you turn the key, does EVERYTHING electrical shut off? If so, check all your grounds and battery cables to be sure they are tight. A loose cable will do this.
  4. #4 Re: 3800 Engine Swap -- will not start -- HELP
    Sounds like a short somewhere or a bad connection.
  5. #5 Re: 3800 Engine Swap -- will not start -- HELP
    Florida
    Put it in neutral, see if it starts.
    Roll the car forward/backward a bit and see if it starts then.
    Check your battery connections, and make sure you are at 12.4v+
    Check your cig lighter fuse. Replace it with a known good fuse and see if you get anything.
    Check all your grounds, and be triple sure they are secure.
    Disconnect the battery and the PCM. Re attach the PCM connections and ensure they are installed correctly. Re connect the battery.
    If that all fails, burn it to the ground.
  1. 3100 engine swap to 3800
    By carlover89 in forum General Grand Prix Discussion
    Last Post: 06-30-2014, 12:04 PM
  2. 3800 Engine swap
    By 007redprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-08-2012, 10:22 PM
  3. 3800 engine swap
    By BrAD19924 in forum Off Topic Discussion
    Last Post: 05-03-2011, 12:58 AM
  4. engine swap 3800 sc to same but not burned engine
    By roger7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 01:59 PM
  5. 3800 engine swap
    By M.$tErNeR in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-26-2009, 05:26 PM
