Thread: Help! With engine code/TPS problem!
Results 1 to 7 of 7
  1. #1 Help! With engine code/TPS problem!
    Banned
    Apr 2013
    Mesa,AZ
    Okay heres the dealio.
    I got my motor back into my 00' GTP, got it fired up and sounds good.
    Heres my problem i cant figure out
    Its throwing a P0122 engine code, TPS circuit voltage low or something along those lines.
    Car wont shift correctly, shift at 4k and havnt gotten it out of 2nd (not registered till emissions can be done)
    Idles high then it should
    I did try swapping TPS sensor with a parts car i have, same deal.
    I did some testing and found out, the power signal to the TPS is 5v like it should be, the ground had 11-12V. Heres where im seeing a problem the middle wire on the tps connector, should real .5v or around there with the throttle closed and the reading on my VDC meter should go up as i slowly open up the throttle, and should go down as i close it. Well...
    When i probe the middle with with power lead to my multimeter and gound the black lead to battery im getting .17V AND when I open throttle i get no change in the reading??? Whats going on?
    I did my testing according to this website
    http://easyautodiagnostics.com/gm_tp..._bad_tps_1.php
    Any suggestions on where to go from here?
  2. #2 Re: Help! With engine code/TPS problem!
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    did you relearn the computer to the changing of the engine ? Anytime you disconnect a sensor it has to be relearned.
  3. #3 Re: Help! With engine code/TPS problem!
    Banned
    Apr 2013
    Mesa,AZ
    It was the same original engine but just freshened it up, how do i relean the sensors? I had everything unplugged when engine was out of the car. Lol
  4. #4 Re: Help! With engine code/TPS problem!
    Donating Users
    Nov 2013
    Indiana
    Interesting, I'm tracking down the same problem....do you have a N* TB?
  5. #5 Re: Help! With engine code/TPS problem!
    Banned
    Apr 2013
    Mesa,AZ
    Nope pretty much stock. I really want to get this issue figured out so i can register/emission and drive this thing! (havnt driven it since ive owned it)
  6. #6 Re: Help! With engine code/TPS problem!
    Donating Users
    Nov 2013
    Indiana
    Above when you mention probing the middle wire and getting a reading of .17 volts are you back probing with the connector still plugged into the tps or are you testing the front of the connector with it disconnected from the tps?
  7. #7 Re: Help! With engine code/TPS problem!
    Sep 2013
    tulsa okla
  1. Problem with loosing bus communication and a p0030 code
    By LapeerGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-11-2012, 11:08 AM
  2. engine code
    By buckslayer in forum 5.3L V8 (LS4)
    Last Post: 03-16-2011, 09:47 PM
  3. Error code p0740 TCC problem
    By johnd89 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 08-04-2009, 09:02 AM
  4. Engine Code
    By the955iman in forum General Tech Discussion
    Last Post: 04-17-2009, 04:40 PM
  5. engine code
    By whitegtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-15-2009, 04:42 PM
