Thread: Weird problems
Results 1 to 3 of 3
  1. #1 Weird problems
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    This might be in the wrong section because I don't know what the problem is
    Heres a good one for you guys:
    Symptoms:
    1. When the car is cold I hear a low whine, once its warmed up its gone.
    2. When I am coming up to a stop light and slowing down from any speed; at exactly 7mph I feel this "bump" sensation under my seat. At first I thought it was my rotors but the more I feel it everyday it seems mroe like a trans issue, but it could be a mount. It only happens one time and only at 7mph. It also only happens when the transmission is totally warmed up.
    3. This happens mostly after 30mph. Say I'm going down the road at 40mph and I instantly press the gas pedal down a few inches, not gradually pressing it but instantly pressing it. Right when I do that I will feel the car jerk and buck a little bit. It def. feels like the trans on this one. Like its downshifting way to hard. I'm pretty sure that this wasn't happening before. It is the same feeling as Problem #2 just a lot more violent.
    All 3 of these problems came about at the exact same time, about a week ago. TIA.
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  2. #2 Re: Weird problems
    SE Level Member blackheart's Avatar
    Aug 2008
    Sumter,SC
    wow i have some what the same ones as 2 and 3.
    I'm you only a little more bizarre
    my 2004 GTP.....http://videos.streetfire.net/video/g...edo_204382.htm
  3. #3 Re: Weird problems
    Barksdale AFB, LA
    #2 is the transmission shifting from 2nd to 1st as you slow down. Never had an automatic trans that didn't do that. Put it in neutral then start slowing down and you'll feel the difference.
    2009 Subaru Impreza WRX STI
  1. weird that my car is doing this!!!!!
    By lilredss0287 in forum Turbo
    Last Post: 12-05-2008, 04:59 AM
  2. weird...
    Last Post: 10-15-2008, 10:56 PM
  3. Weird shifting problems
    By Sick03L in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2008, 07:48 PM
  4. weird noise
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2008, 04:17 PM
  5. weird electical problems, I am thinking BCM
    By 01whitegtp in forum General Tech Discussion
    Last Post: 01-12-2008, 03:37 PM
