Thread: Alternator Belt Removal Help
Results 1 to 9 of 9
  1. #1 Alternator Belt Removal Help
    SE Level Member Talsition's Avatar
    Stevens Point, WI
    Ok I am having a damn hard time trying to get the belt off and its cold up here in wisconsin and I am working on it out side in the snow. So here is my problem I am not sure where the tensioner is to release the belt. I thought I knew where it was but I try and turn it either way and nothing happens. Here is a pic.
    Please tell me I don't have to remove both belts.
    98 Grand Prix GTP - Custom FWI, 104 autolites, 180* t-stat, TDR Fbody Break Kit
    95 Eagle Talon ESI - 2Gb Conversion, lots of mods still slow.
  2. #2 Re: Alternator Belt Removal Help
    Oklahoma
    The tensioners go in opposite directions. The one for the supercharger releases turned one way and the one for the accessories releases turned in the other direction but I dont remember which is which. I want to say the accessory belt (the one for the alternator) releases when its pushed to the right. If you are just replacing the alternator you shouldnt have to take the belt completely off, just release the tension and slip the belt off the alternator.
    If its difficult to move the tensioner in the direction of releasing tension there may be an issue with the tensioner, but Ive never seen that kind of issue before with them. You may need to use a longer bar or something like that to get enough leverage. I normally just use a 8", 3/8" drive breaker bar but you're up there in the salt belt too so Im not sure what the exposure to all that would do to that tensioner over time.
  3. #3 Re: Alternator Belt Removal Help
    Banned
    Wichita Falls, Texas
    Thats the right one.
  4. #4 Re: Alternator Belt Removal Help
    Oklahoma
    Whoa! What kind of freak behemoth is that. Your alternator is down where my power steering pump is and that upper motor mount is on the wrong side.
  5. #5 Re: Alternator Belt Removal Help
    Stevens Point, WI
    alright ill bust out the breaker bar and see what happens. Thanks guys
  6. #6 Re: Alternator Belt Removal Help
    Banned
    ROFL
  7. #7 Re: Alternator Belt Removal Help
    Feb 2008
    I'm soo confused, Street... Why would you go and do this to me?!?
  8. #8 Re: Alternator Belt Removal Help
    Stevens Point, WI
    Yeah I got it only takes 10 min to get it out once I got that tensioner figured out.
  9. #9 Re: Alternator Belt Removal Help
    chicago
    hey wolfy i'm going to upgrade to 3.5 tensioner pulley can you circle where it is?
  1. Alternator output
    By Dohner in forum Audio, Security & Visual Electronics
    Last Post: 03-31-2009, 11:25 PM
  2. Alternator ????????
    By kingbrentdwyer in forum General Tech Discussion
    Last Post: 10-27-2008, 11:01 PM
  3. ZZP Alternator Rewire
    By adidasdude1061 in forum Audio, Security & Visual Electronics
    Last Post: 09-20-2008, 05:45 PM
