Thread: Supercharger Bolt Locations - Need Help
Results 1 to 19 of 19
  1. #1 Supercharger Bolt Locations - Need Help
    SE Level Member Primal's Avatar
    Aug 2013
    Old Saybrook, CT
    Hey All!
    I'm FINALLY finishing up this LIM gasket job. Lot's of lessons learned and lots of problems found and fixed that I didn't know I had originally.
    Now, I've got the Supercharger back on and I'm not 100% sure where the bolts go.
    Here is what I have in the baggie labeled "Supercharger:
    The bottom left one that says "SC Passenger rear" I somehow think I mislabeled and it needs to go on the Driver's rear corner. I don't know why I think that. It was a while ago when I pulled it apart.
    Anyway, some help sorting out where these bolts go would be a HUGE help.
    Thanks!
    Adam
  2. #2 Re: Supercharger Bolt Locations - Need Help
    Aug 2013
    Old Saybrook, CT
    OK, so the medium length 8 bolts I pretty much found the locations for. Two went into the locating pin holes and the other six just went around in obvious places.
    The two short ones I don't think hold the S/C down at all but are used to mount a bracket with some kind of electrical deal on it (Anyone know that electrical deal is???)
    So, really the only question is the two long ones. The top one labeled "SC Front" I put in the thick part of the supercharger flange to the left of the snout in the front. The one with the nut on top of it I put at the rear of the engine in the thick flange.
    But, what goes under that nut - if I do indeed have that rear long bolt in the right place?
    I didn't torque anything down yet - just went hand tight since I haven't received a reply on here yet.
    Thanks again!
  3. #3 Re: Supercharger Bolt Locations - Need Help
    Feb 2013
    37.295091, -121.930053
    this is what i did try each bolt in the location you think it goes to. keep in mind i had mine off for 5 months and didnt lose any bolts. the stud one goes on the drivers side towards the windshield and the other bolt with blue tape is for the snout I believe bill will know for sure. best of luck
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  4. #4 Re: Supercharger Bolt Locations - Need Help
    2 small ones hold the bracket down.
    Looks where my 2 fingers are
    04 Comp G.
  5. #5 Re: Supercharger Bolt Locations - Need Help
    Feb 2013
    i have one that wont go back in the sc lol im going to get a shorter bolt for it but yeah ^^ small bolts go there
  6. #6 Re: Supercharger Bolt Locations - Need Help
    Aug 2013
    Old Saybrook, CT
    Thanks for snapping the pic, man. Yeah, I have the two small ones on the bracket.
    I think now it's just what the hell goes under the stud bolt. From what ericspecullaas I was correct that I mislabeled the bolt with the stud on top.
  7. #7 Re: Supercharger Bolt Locations - Need Help
    Stud bolt?
    04 Comp G.
  8. #8 Re: Supercharger Bolt Locations - Need Help
    Aug 2013
    Old Saybrook, CT
    Bottom left in the FIRST PIC AT THE TOP OF THE THREAD with all the bolts laid out. I actually think I figured it out. It mounts a tab that's on the circular "shield thing" that goes around the whatever the hell it is on the exhaust. Is that the EGR valve?
    I circled the part I'm talking about. There's a tab that goes over that rear S/C bolt on the stud on top and then nut goes over that and gets tightened.
  9. #9 Re: Supercharger Bolt Locations - Need Help
    Yup, thats the EGR.
  10. #10 Re: Supercharger Bolt Locations - Need Help
    Yup.. you got it. The stud goes in teh back supercharge aka rear driver and then the egr shield, and nut. The two short ones hold the map sensor bracket.
  11. #11 Re: Supercharger Bolt Locations - Need Help
    Aug 2013
    Old Saybrook, CT
    Thanks, everyone! Freakin' crazy that I mislabeled that one though.
    Thanks for helping me sort it all out.
  12. #12 Re: Supercharger Bolt Locations - Need Help
    Just toss up a pic of a bolt.. we can tell you w/o you even knowing where or what it goes to.
  13. #13 Re: Supercharger Bolt Locations - Need Help
    GT Level Member TwiztdWun's Avatar
    Feb 2013
    Ohio
    This is true. I was a GM tech and got out of it right when this platform first hit the streets. While I feel my knowledge is above par, it is impossible to beat the collective resources on this forum.
  14. #14 Re: Supercharger Bolt Locations - Need Help
    Aug 2013
    Old Saybrook, CT
    Quote Originally Posted by TwiztdWun View Post
    For sure! I've been into cars my whole life and even built a 400 HP Small Block Chevy for my Nova when I was 19. But the modern cars I don't have a lot of experience with. This forum not only saved me from a project that was way over my head, but got me into the whole 3800 platform and feeling good about owning the GTP in general.
    I feel like a "car guy" again as opposed to a "used to be a car guy."
    Thanks everyone - especially Bill!
    Adam
  15. #15 Re: Supercharger Bolt Locations - Need Help
    Adam.. wanna feel into the 3800's.. just stop in one day.
    There's three L67's on the floor, two mated to transmissions, a dead L36 that needs to be returned for a core charge, wiring harnesses, dipsticks/tubes hanging on the wall, parts galore basically. Those are all next to the tools to get the job done.
  16. #16 Re: Supercharger Bolt Locations - Need Help
    Aug 2013
    Old Saybrook, CT
    Sounds like a party, man! I'll have to take you up on that!
  17. #17 Re: Supercharger Bolt Locations - Need Help
    Holler when you are ready. I'm willing to put you to work too
    That's how guys learn. Hands on.
  18. #18 Re: Supercharger Bolt Locations - Need Help
    Aug 2013
    Old Saybrook, CT
    I wouldn't mind at all!
  19. #19 Re: Supercharger Bolt Locations - Need Help
    Feb 2013
    Dont forget to ask questions if your not sure
  1. Supercharger bolt
    By Marshalgrundy in forum General Tech Discussion
    Last Post: 12-13-2012, 12:49 PM
  2. I need a supercharger idler pulley bolt
    By FaxMeBeer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2011, 12:55 PM
  3. Supercharger bolt length gen 3
    By sseilmnop in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-28-2011, 09:55 PM
  4. Supercharger vented bolt???
    By jagamite in forum General Tech Discussion
    Last Post: 11-04-2008, 08:13 AM
  5. Supercharger Fill Hole Bolt Stripped
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2008, 06:20 AM
