Just began a new build, right when I thought I would steer away from Montes.
Going to be a Gen V, S1x, Lightly ported heads and e85 build.
This will max out the stock heads and give me a chance to upgrade heads in the future.
I just picked up the Gen V today, N*, MAF and adapter are on the way.
Still not sure what I'm going to do for the motor. I may be going with an L32 or jumping straight to the L67, it all depends on what I can find.
Here's what I have right now, this blower was in a fire, not warped, everything is cosmetically okay and there is zero play in the pulley and the pulley spins freely. Still even about 95% of the coating on the rotors.
Gen V supercharger by trewyn15, on Flickr
I'll be updating like crazy, should be about a year long build tho, taking time with it :thumbsup:
The rest are posts that I have made on my original build thread:
This thing is cleaning up quite nicely, I don't have much for wire wheels on my dremel, so it will only get better once I get some of those in.
Untitled by trewyn15, on Flickr
Went to Ace today and got some new stuff to get this snout off, going to need an impact though more than likely in order to get it off. You can also see the color I decided to paint, going to be a stock looking build but with some more accents of which will be seen when I get the engine. It's an aluminum silver.
time for cleaning by trewyn15, on Flickr
Went through a whole battery as well with the wire wheel, this thing is cleaning up surprisingly easy and well.
Will get a bit more today and this weekend when I can get it apart fully and degrease the whole thing, hopefully paint this weekend as well.
I will continue to update this thread as the build continues!
