I have a 2004 Grand Prix GTP and have had a "shaking" issue as I can best describe it with this car for a while. If you can picture sitting in the drivers seat and taking your foot off the brake pedal and just let the car creep forward without touching the gas the motor literally shakes the car. The issue seems to be more pronounced when I first start it up in the morning, but this issue happens when I reverse out of my garage as well. Any insight would be great! As well, I believe that my LIM gaskets are done, as I had a leak coming from my water pump and just replaced it, but my car seems to be running "hotter" then it did before, but I am seeing coolant sitting by my fuel injectors as I had dye placed in the coolant to detect my water pump issue. If possible could someone leave a "complete shopping list" of parts I need for this job. I was going to use the FEL-PRO MS98014T Intake Manifold Gasket Set but I need to know what else I will need that is not included in said gasket set. My list so far for the job is as follows:
FEL-PRO Part# MS98014T Intake Manifold Gasket Set; Lower set
FEL-PRO Part# MS96789 Plenum Gasket Set; Upper set
DORMAN Part# 47065HP Elbow; Aluminum; w/O-ring Seal; Includes Upper & Lower Elbow Aluminum Elbow w/O-ring Seal; Incl. Upper and Lower Elbow
Oil/Filters and coolant
Thanks again for your time in reading my issue's and your helpful knowledge and responses!
