Thread: NEW AC based INTERCOOLING SYSTEM!!!! (will require slight retro fit)
Results 1 to 20 of 27
  1. #1 NEW AC based INTERCOOLING SYSTEM!!!! (will require slight retro fit)
    Here is a new IC system that use the AC system from your car to drop the intake temp 20 to 30 Degree easily. The kit will require slight retro fit to get as this is a (Universal) kit being used on a new gen Camaro. The kit is 900 dollars off the website. Yes 900 is 900 dollars however look at what other air to water kits cost. The others are at or near this price and Im willing to bet this kit will work better with out having to use a water IC pump as this uses the AC pump already in your car.
    http://www.revxtreme.com/rx-super-ch...e=superchiller
    Here is the whole tech article. YOUR WELCOME!
    Cough Cough ** combine this with the uber efficient TVS...................
  2. #2 Re: NEW AC based INTERCOOING SYSTEM!!!! (will require slight retro fit)
    damn it some mod fix the title Im missing the L in intercooLing
  3. #3 Re: NEW AC based INTERCOOING SYSTEM!!!! (will require slight retro fit)
    Dec 2012
    Where 4T65E's were born
    Hit: Edit > Go Advanced > Edit title.
    Sold.
  4. #4 Re: NEW AC based INTERCOOLING SYSTEM!!!! (will require slight retro fit)
    need the damn like button back thanks guy^^^^ im smrt(er) now.........
  5. #5 Re: NEW AC based INTERCOOLING SYSTEM!!!! (will require slight retro fit)
    Sep 2013
    Colorado Springs, CO
    I'd like to see pics of this installed, the Mustang / Lightning guys have used the www.killerchiller.com for years.
  6. #6 Re: NEW AC based INTERCOOLING SYSTEM!!!! (will require slight retro fit)
    Nov 2011
    NY
    Interesting... But those two sites harp on lowering the fluid temp without saying how much it lowers the AIR temp. Interesting none the less, bookmarked and will keep an eye on this. Maybe a project for next spring : )
  7. #7 Re: NEW AC based INTERCOOLING SYSTEM!!!! (will require slight retro fit)
    GT Level Member orange57's Avatar
    Aug 2012
    Chandler, AZ
    if i read the description right, it sounds like it chills the water in an air water ic using the AC system. since I only have my phone on me right now, i'll look at it a little bit later on the comp again. I'm also guessing you will need more refrigerant for the load of the intake air temp in order to not reduce the capacity of the cabin coil.
  8. #8 Re: NEW AC based INTERCOOLING SYSTEM!!!! (will require slight retro fit)
    im not buying into it. after he gets on it, (not for very long either) the ait temps are back to 90, where it was before the chiller was turned on.
    seems the chiller cant keep up with the air the engine needs. i know the a/c compressor turns off at wot, so how does this thing help, other then good chilled cruising temps. and how the F do you tune for cold air at first then warm to hot?
    and what about the cars a/c? im certainly not trading my ice cold a/c for this crap set up.
    im calling it snake oil sales lol
  9. #9 Re: NEW AC based INTERCOOLING SYSTEM!!!! (will require slight retro fit)
    If the car didnt have the chiller the temp would stay are 80-90 then rise even more to well over 100 and take longer to cool back down. Seems like it would take well over 10 seconds to start hitting above 100º intake temps with that chiller compared to a normal intake system that would make temps jump from an already warm air to even hotter.
    And you wouldn't even have to really tune for it, the car is smart enough on its own to know what to do. Sure maybe you could add more fuel/timing yadda yadda right away then just let the car determine what's best as time goes on.
    The vehicles A/C is not changed, its just added on to, the system works 100% normal as it always would. You are just adding more to it thus why in the specs it says it would need 5-6oz extra of freon for the added lines.
    I think its an okay idea, but its not for everyone.
  10. #10 Re: NEW AC based INTERCOOLING SYSTEM!!!! (will require slight retro fit)
    Arizona
    Theve been doing doing this for the zl1 camaros a d caddies for a while now. Works great for them. Iirc a 3800 guy did it too.
  11. #11 Re: NEW AC based INTERCOOLING SYSTEM!!!! (will require slight retro fit)
    Considering that the coolant temp is certainly higher when the car goes into open loop, I don't see how this kit would not be beneficial. No matter how you look at this is more stable than the systems relying on coolant temps.
  12. #12 Re: NEW AC based INTERCOOLING SYSTEM!!!! (will require slight retro fit)
    Nov 2011
    NY
    I think it could work... But is fishy that only the coolant temp is mentioned when the actually benefit comes from lower the air temp and those numbers aren't quoted. I'm sure using the a/c system, condenser/cooling concept can cool the liquid to the Intercooler better than just outside air. That said I think it's recovery will be limited meaning your limited to one pull probably on cooled air! Then you'll be at the same advantage/disadvantage of just Intercooled alone.
    But like anything, there's only one way to find out, and that's by sacrificing yourself on the altar of benefitting everyone else and being the test case. Lol...
  13. #13 Re: NEW AC based INTERCOOLING SYSTEM!!!! (will require slight retro fit)
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by 91parkave View Post
    Ron Vogel tried it, either that or Mike from Wbody store, one of the two.
  14. #14 Re: NEW AC based INTERCOOLING SYSTEM!!!! (will require slight retro fit)
    was it worth a damn or no?
  15. #15 Re: NEW AC based INTERCOOLING SYSTEM!!!! (will require slight retro fit)
    Mullet Member Wotgtp's Avatar
    Connecticut
    GTO guys have been doing this with their TVS/pro charger setups. They work great.
  16. #16 Re: NEW AC based INTERCOOLING SYSTEM!!!! (will require slight retro fit)
    Nov 2011
    NY
    Quote Originally Posted by Wotgtp View Post
    Hahaha... And are you? I've gots ta know...
  17. #17 Re: NEW AC based INTERCOOLING SYSTEM!!!! (will require slight retro fit)
    Feb 2009
    flintnasty MI
    Benifits are in the single digit range for power... I would rather spend the money on a turbo or nitrous vs a $2500+++ intercooler for my $1500 grand prix.
  18. #18 Re: NEW AC based INTERCOOLING SYSTEM!!!! (will require slight retro fit)
    Connecticut
    Quote Originally Posted by coolone View Post
    Ha, I wish. For now non-intercooled is more than enough power for me.
  19. #19 Re: NEW AC based INTERCOOLING SYSTEM!!!! (will require slight retro fit)
    iowa
    retarded. so you're gonna have the drag from the ac compressor to gain what, about 15 hp on a good day?
    87 buick gn-fmic, 3200 stall, meth injection, gt35r/76ptrim at 24psi, 204/214 cam, 60lb injectors (at 95%dc)
    .....Then there's the wife's driver
  20. #20 Re: NEW AC based INTERCOOLING SYSTEM!!!! (will require slight retro fit)
    Quote Originally Posted by usetaboost View Post
    A wonderful post.
    Truely amazing.
    Clearly you didnt read it, nor understand how most A/C systems work. A/C's shut off upon WOT or at given rpms, and no matter what car you drive that has a A/C system, that pulley will always be there so when its off how is the drag any different.
    And as said before, its not worth the cost on a vehicle like ours nor on many cars. If you have the money to burn, but it or just go turbo.
  1. Android based sound system????
    By Kilroy in forum Audio, Security & Visual Electronics
    Last Post: 08-03-2013, 10:27 AM
  2. i require a measurement!
    By Adasm in forum Brakes/Suspension/Chassis
    Last Post: 01-14-2013, 04:22 PM
  3. Best PC based scanner
    By winston in forum General Tech Discussion
    Last Post: 11-12-2011, 10:27 AM
  4. I require your vast knowledge!
    By 99PontiacGTP in forum General Tech Discussion
    Last Post: 09-08-2011, 07:49 PM
  5. i know this is only opinion based but...
    By BoostedComp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2010, 09:07 AM
