Thread: 1999 Grand Prix GTP exhaust
Results 1 to 18 of 18
  1. #1 1999 Grand Prix GTP exhaust
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    I have a few questions. I know with many cars, if you removed the catalytic converter the car would freak out because the pcm wasn't reading what it is supposed to read. But I heard that the 1999 - 2000 Grand Prix GT could have the catalytic converter removed without tripping any codes. My question, does the 1999 Grand Prix GTP pcm also not trip codes when the exhaust is tampered with? For example, removing bends and backpressure often causes a Service Engine Light and messes with the cars performance and economy. Does anyone know more information about the 1999 GTP and if it is affected by removing/messing with the backpressure? I would like to take some of the bends out of the exhaust system and, if possible, use a bit bigger diameter piping. I am just wondering if doing that would trip a code or not. Thanks in advance for any answers =)
  2. #2 Re: 1999 Grand Prix GTP exhaust
    The factory cat back is of no concern to you. You will not outflow the pipe size untill roughly 350WHP or more. Your car now has maybe 200 WHP if stock.
    The cat converter is not an issue either, that flows fine. Its the pipe size of the downpipe into the converter and the u-bend in the exhaust for the rear o2 sensor. Most people buy a 3in downpipe to remove both problems and give the car a small bump in power and help reduce KR.
    So in short, back pressure is pretty much a myth with these cars and on 97-00 cars the cat converter will not matter as the vehicle does not use the rear o2 sensor to control anything. The sensor is only there to see if the cat is there or not. So if you remove the converter the light may come on but it means nothing.
  3. #3 Re: 1999 Grand Prix GTP exhaust
    Aug 2011
    Michigan
    Okay, thank you for the information. I have one other question. How high should my boost get stock? My boost gage, the stock one, only gets up to about half way. Is that about where it should be stock?
  4. #4 Re: 1999 Grand Prix GTP exhaust
    Max Cook
    Guest
    It should be able to fill the lego blocks at stock levels. You may have a vac leak. Check your vac lines.
  5. #5 Re: 1999 Grand Prix GTP exhaust
    Aug 2011
    Michigan
    When its cold it fills the lego blocks, but 99% of tge time it goes no higher than half way
  6. #6 Re: 1999 Grand Prix GTP exhaust
    A real vacuum/boost gauge would help alot more.
    Its too hard to say if its the info center thats wrong or if indeed you have a vacuum leak or a plugged up exhaust system that happens as the car warms up.
    I'd check all vacuum lines for cracks and such as its free and replace them as needed.
  7. #7 Re: 1999 Grand Prix GTP exhaust
    Aug 2011
    Michigan
    I'd be willing to bet its a vacuum leak, like most of the time the boost will build at max half way and sometimes bounce between half and half+1 block. My exhaust I can safely say should not be plugged since for the past week or so it has been disconnected from the catalytic converter which I am fixing today. I had a "wastegate solenoid" code come up once but it came on when the boost gage ended up reading max boost.
  8. #8 Re: 1999 Grand Prix GTP exhaust
    Aug 2011
    Michigan
    Okay, I have checked and found no vacuum leak anywhere. The car still only builds between just under half and just over half boost.
  9. #9 Re: 1999 Grand Prix GTP exhaust
    GT Level Member MBruneaux's Avatar
    Canterbury, CT
    Quote Originally Posted by tomtom123 View Post
    Invest in a real boost gauge, maybe someone here can recommend a good one since I need one also.
    2001 Grand Prix GTP - Daily Driver12" front brake upgrade ('05 Monte), Raptor tune, Open cone, Front and rear strut tower braces, SS brake hoses, BMR trailing arms, ZZP 3" catted downpipe, Dorman front sway bar, GMPP rear sway bar, solid trans and engine mount, flipped dog bones and Borla exhaust.
  10. #10 Re: 1999 Grand Prix GTP exhaust
    Aug 2011
    Michigan
    I don't see how a "real" boost gauge is going to solve the issue. It is quite noticeable when it's measuring half boost compared to when it's measuring full boost. That to me indicates there is something more than just the boost gauge not properly measuring the amount of boost. Am I wrong?
  11. #11 Re: 1999 Grand Prix GTP exhaust
    Dec 2010
    DMV
    Try the bbv solenoid if a leak can't be found.
    Sent from my HTC One using Tapatalk 2
  12. #12 Re: 1999 Grand Prix GTP exhaust
    Aug 2011
    Michigan
    Blue, how do I test that? Just by replacing it? I was thinking it might be that solenoid but I haven't been able to find it anywhere other than from GM in a kit they sell that I heard was around $250 =/
  13. #13 Re: 1999 Grand Prix GTP exhaust
    Dec 2010
    DMV
    I had the same issue before. Let me see if I can find the post. It may just be the solenoid. I'm sure you can get one from the wanted parts section.
  14. #14 Re: 1999 Grand Prix GTP exhaust
    Aug 2011
    Michigan
    Alright Blue. Like the car randomly will build full boost, but most of the time builds between 4 - 6 blocks. I was messing with the solenoid but couldn't find anything that seemed to help fix the issue.
  15. #15 Re: 1999 Grand Prix GTP exhaust
    in park, goose the gas, watch the lever on the boost solenoid, is it moving? its supposed to.
  16. #16 Re: 1999 Grand Prix GTP exhaust
    Aug 2011
    Michigan
    Yes, when idling the bar is like all the way up/open, then as the car is gassed the bar goes down/closes
  17. #17 Re: 1999 Grand Prix GTP exhaust
    Aug 2011
    Michigan
    I don't believe any of the vacuum lines are leaking, can't find a leak anywhere. When the car is cold, when I first start the car in the morning it will build full boost, but after a few minutes it starts only building about half
  18. #18 Re: 1999 Grand Prix GTP exhaust
    Aug 2011
    Michigan
    I'm pretty sure its the boost bypass solenoid, or the sensor for it because I unplugged the pressure line coming into it and now it builds full boost.
  1. 1999 Grand Prix GT Exhaust System
    By corxbeans in forum General Grand Prix Discussion
    Last Post: 06-17-2013, 09:35 AM
  2. is the 1999 grand am stereo the same as a 2001 grand prix gt?
    By llinziee in forum Audio, Security & Visual Electronics
    Last Post: 07-06-2011, 03:51 PM
  3. I need some help with my 1999 Grand Prix GTP!
    By Melissa91 in forum General Tech Discussion
    Last Post: 05-24-2011, 08:24 PM
