Thread: 1998 v6 supercharge rack n pinion
Results 1 to 9 of 9
  1. #1 1998 v6 supercharge rack n pinion
    Sep 2013
    How can I tell if I need a magnasteer or not can I get a rack n pinion cheap?
  2. #2 Re: 1998 v6 supercharge rack n pinion
    If it is magnasteer you'll have a wiring harness coming off the rack
  3. #3 Re: 1998 v6 supercharge rack n pinion
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    If you get a rack and pinion from a junkyard you can get it fairly cheap. I got mine for 28$ Just find a low mile car with magnasteer and then pull the tie rod boots off to make sure theyre not full of fluid.
    I went NA when a whore left -$300 in my bank account.
  4. #4 Re: 1998 v6 supercharge rack n pinion
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    IIRC everything 98+ GT and GTP had magnasteer, SE's were w/o magnasteer. Only 97 had magnasteer as an option... But I could be wrong...
    But yes, if it's a magnasteer unit there's a two pin plug coming off your rack below where the steering shaft attaches.
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  5. #5 Re: 1998 v6 supercharge rack n pinion
    Dec 2012
    troll land
    You dont have to run the mag steer tho
  6. #6 Re: 1998 v6 supercharge rack n pinion
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    Ebay from detroitaxle. I got mine with Magnasteer for $104. Works great.
    No point in not running mag steer if you have the option. Mag steer is only a few bucks higher.
  7. #7 Re: 1998 v6 supercharge rack n pinion
    Sep 2013
    Ok another incident i took the cap of radiator and water got on belt. belt slip of and broke the metal that the belt tensioner is on off the motor. Is this fixable? I want this car
  8. #8 Re: 1998 v6 supercharge rack n pinion
    post a pic of this damage, sounds like the tensioner broke.
  9. #9 Re: 1998 v6 supercharge rack n pinion
    Dec 2012
    troll land
    Would kinda like to wire up the mag steer in my 97 monte but i havent figured out where to wire it to i know one goes to vss but wut about the other one? Sorry to thread jack
  1. rack and pinion
    By asite57 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2011, 09:53 PM
  2. rack in pinion
    By 2005GrandPrix in forum Brakes/Suspension/Chassis
    Last Post: 10-25-2011, 04:28 PM
  3. P.S. Rack and pinion? PLEASE HELP!!
    By dwc1435 in forum Brakes/Suspension/Chassis
    Last Post: 02-28-2011, 01:16 PM
  4. rack and pinion
    Last Post: 02-21-2011, 09:53 AM
