Thread: Acting weird
Results 1 to 16 of 16
  1. #1 Acting weird
    GTX Level Member 98buicksupercharged's Avatar
    Oct 2012
    Fort Wayne, Indiana
    Okay so I have an 01 gtp.
    When I'm driving the Rpms will drop on the tach
    other times the Rpms drop and the car shuts off and takes a bit of work to start Again. Sometimes it just acts like I have a dead battery
    any opinions?
    2001 sliver gtp her name is Reagan
  2. #2 Re: Acting weird
    sounds like a crank sensor, but check all your grounds first.
  3. #3 Re: Acting weird
    Replace the crank sensor yet?
    Tach dropping to zero while driving is the very common crank sensor failure.
  4. #4 Re: Acting weird
    Oct 2012
    Fort Wayne, Indiana
    Oh okay. And I have not changed yet. How hard are those to replace?
  5. #5 Re: Acting weird
  6. #6 Re: Acting weird
    They aren't to bad if you can get the crank off
  7. #7 Re: Acting weird
    Oct 2012
    Fort Wayne, Indiana
    That's the only thing I'm worried about. Trying to get the crank but off. I need to do it today. It took me 30 minutes of battling to start my car today
  8. #8 Re: Acting weird
    Breaker bar+ a long extension + vice grips on the flexplate should pop it loose. If not you can try to possibly take it to a mom n pop shop and see if the they're willing to loosen it with a impact enough for you to do the rest at home.
    04 Comp G.
  9. #9 Re: Acting weird
    or the red neck way.
  10. #10 Re: Acting weird
    Redneck way always works
  11. #11 Re: Acting weird
    Oct 2012
    Fort Wayne, Indiana
    We will see. Guess I'm riding bike to work for a while
  12. #12 Re: Acting weird
    I might be up in ft Wayne this weekend. My dad's in luthren. I could help out if you need
  13. #13 Re: Acting weird
    Oct 2012
    Fort Wayne, Indiana
    That's not good man. And yeah if I decide to do it your always welcome!
  14. #14 Re: Acting weird
    I'll text you if I head up there and have time. I might take the bike to save on gas if it's nice out so I wouldn't be able to bring any tools with me.
  15. #15 Re: Acting weird
    SE Level Member marineinmichigan's Avatar
    Oct 2013
    Speed control sensor causes symptoms like that
    Sent from my SPH-L720 using Tapatalk
    Using Tapatalk
  16. #16 Re: Acting weird
    Dec 2012
    Where 4T65E's were born
    Check grounds first. "acts like I have a dead battery" is not a crank sensor symptom. It would still crank. Also when you say that, do you mean that even the lights inside are dim or not on at all? Or the starter just won't engage or turns slowly?
    Sold.
  1. car rpm's acting weird after warm up and only in drive and reverse
    By 2000supercharged in forum General Grand Prix Discussion
    Last Post: 01-16-2013, 01:14 PM
  2. Transmission acting weird during startup
    By guitarguyucf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-05-2011, 11:09 PM
  3. please help tranny acting weird
    By ryan88z in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-05-2008, 09:17 PM
  4. Forums Acting Weird
    By 19SE92 in forum Forum Bugs/Suggestions
    Last Post: 02-29-2008, 08:03 AM
  5. Help please!!! Electrical system acting weird, Car won't start now!!
    By Tkuligowski in forum General Tech Discussion
    Last Post: 01-24-2008, 08:42 PM
