Okay so I have an 01 gtp.
When I'm driving the Rpms will drop on the tach
other times the Rpms drop and the car shuts off and takes a bit of work to start Again. Sometimes it just acts like I have a dead battery
any opinions?
any opinions?
They aren't to bad if you can get the crank off
That's the only thing I'm worried about. Trying to get the crank but off. I need to do it today. It took me 30 minutes of battling to start my car today
Breaker bar+ a long extension + vice grips on the flexplate should pop it loose. If not you can try to possibly take it to a mom n pop shop and see if the they're willing to loosen it with a impact enough for you to do the rest at home.
Redneck way always works
I might be up in ft Wayne this weekend. My dad's in luthren. I could help out if you need
I'll text you if I head up there and have time. I might take the bike to save on gas if it's nice out so I wouldn't be able to bring any tools with me.
Check grounds first. "acts like I have a dead battery" is not a crank sensor symptom. It would still crank. Also when you say that, do you mean that even the lights inside are dim or not on at all? Or the starter just won't engage or turns slowly?
