Thread: Powerbond sfi balancer bolt torque
Results 1 to 3 of 3
  1. #1 Powerbond sfi balancer bolt torque
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    Anyone know the torque spec for the crank bolt on the Powerbond SFI balancer? Thanks for any help.
  2. #2 Re: Powerbond sfi balancer bolt torque
    A good blap with the air gun should work.
    I assume its still the same as the stock spec, because the crank is the same. Going too tight will just ruin threads.
  3. #3 Re: Powerbond sfi balancer bolt torque
    Lorain, OH
    Yeah, stock is torque to yield though and most aftermarket hardened bolts etc are not TTY. I gave it the impact gun torque spec.. so It should be fine just wanted to know if anyone had the actual spec that it called for.
  1. Harmonic balancer bolt size
    By 99prixgt in forum General Tech Discussion
    Last Post: 02-10-2013, 08:51 PM
  2. whats behind the first bolt on the harmonic balancer?
    By Shiftingshaddow in forum General Tech Discussion
    Last Post: 01-27-2013, 12:51 AM
  3. Harmonic Balancer Bolt Removal
    By h0wl0ngcanitbe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-29-2012, 09:35 AM
  4. Replies: 7
    Last Post: 04-19-2012, 12:44 AM
  5. How to hold Harmonic Balancer Still to Remove Crank Bolt?
    By pontiackid in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2009, 09:00 PM
