Just re read your original post. Sorry I thought you mentioned a stage 3 type cam in your next build with the heads. You really won't need a double roller timing chain with a mild cam and 90lb springs. I run a single roller which is stronger than stock. Did you replace the timing chain on the last build? If so with what? Im pretty sure a double requires some machining of timing chain cover. I gapped 104's to .048. Depending on how much work was done on your ported heads the gains may be minimal but every little bit helps...
