Thread: Replacing fuel injector tips?
Results 1 to 5 of 5
  1. #1 Replacing fuel injector tips?
    gardner,mass
    So ive been chasing a misfire and came across this. 4 of them look like this.
    Is it possible to replace these tips?
    Also could this be my cause of misfire from allowing unmetered air into the cylinder?
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  2. #2 Re: Replacing fuel injector tips?
    That should be fine. The o ring seals still
  3. #3 Re: Replacing fuel injector tips?
    GT Level Member WolvesSoulZ's Avatar
    Québec
    The tip is just a retainer, doesn't affect the sealing ability of the o-ring. Not that I think so either.
    Last I looked, I didn't find a part number for these when I broke one off when I installed my cam, just used an old one from one of the few injectors laying around for the sake of it, otherwise would've ran it without the retainer, just the o-ring.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  4. #4 Re: Replacing fuel injector tips?
    gardner,mass
    Well then i need to figure out this misfire.....
    more info
    http://www.grandprixforums.net/fuel-pressure-82109.html
  5. #5 Re: Replacing fuel injector tips?
    Mar 2013
    Colorado - USA
    I had a similar problem over the summer, immediately after engine work that required me to pull the fuel rails.
    http://www.grandprixforums.net/cam-s...ml#post1027494
    E85 L32 S1X Heads 105#Crow Springs LQ4 2k+NStarTB Deka 60# Gen1 SLP Headers Stock Plugs
    19 deg GFS and ZERO KR@14 PSI <10% LTFT
    GMPP Struts/Springs SLP Sway Bars Z06 Brakes
  1. Tips for replacing steering rack
    By stingray355 in forum How To Write-Ups/Tech Tips
    Last Post: 06-24-2013, 01:12 PM
  2. Replacing Injector O-ring's [*]
    By J_Ferguson in forum How To Write-Ups/Tech Tips
    Last Post: 04-25-2013, 12:48 PM
  3. Fuel injector help !!!!
    By GTPAIELLO in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2012, 06:48 AM
  4. Fuel Injector Cleaning
    By Burbman in forum General Tech Discussion
    Last Post: 12-04-2012, 11:58 AM
  5. Replacing Injector
    By TCO in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-10-2009, 05:12 PM
