2000 3.8 GTP, just wanted to do some work to the top end of the motor so it got NEW : Head Gasket, Upper and lower intake gaskets, Plugs and wires (Autolite), coil pack. When I first put it back together it was first showing multiple misfire code, then that one went away when engine warmed up and it threw "Misfire on Cylinder 6". Alright, so I figured only thing I didn't replace was the injectors, so I SWAPPED injectors between cylinder 1 and 6. I put it back together and at first start it showed again multiple misfire, it went off and then it threw MISFIRE #1(And lean on bank 1). Ok, I was POSITIVE injector was bad because the code just went from misfire #6 to misfire #1 now. So, I replace the injector, AND the coil pack for cylinder #1. Code is still on. After all, new head gasket, new plugs and wires, new coil, new injector, why in the world is it misfiring on one cylinder? (Wires are to each correct cylinder from coils so no issue there). Thanks a lot guys
