Thread: oil leak
Results 1 to 5 of 5
  1. #1 oil leak
    Aug 2008
    canada
    i have an oil leak, i put my car up on the ramps to change the oil and the base pan and trans were covered in oil. cant find the leak, it is a slow leak, i drove 300 k and it never moved on the dip stick. is there a common oil leak that i could check first ? the car is a 1998 gtp
  2. #2 Re: oil leak
    TDCRacing
    Guest
    Quote Originally Posted by whitegtp View Post
    Best thing to do is clean and then inspect.
    Could be a lot of things. The common things i guess you could say would possibly include the Oil pan gasket,front or rear main seals ect.
    I would lean more twards the oil pan gasket.
  3. #3 Re: oil leak
    Aug 2008
    canada
    it kind of seems like the oil pan gasket
  4. #4 Re: oil leak
    SE Level Member justaV6's Avatar
    Oct 2008
    Liberty, MO
    mine did they same thing and i was the oil pan gasket
    1999 AW GTP Sedan FWI w/ K&N, ZZP MPS 3.4", S1X, SD Headers, GBP Ported SC/TB, LS6 Springs/Retainers, Intense Racing Tuned PCM, 160* T-Stat, AL104's, MSD Coils/8.5mm wires, TEP Street/Strip Race Trans w/ 3.29's, GMPP FSB, GMPP F&R STB's, 12" Upgrade...and more.
  5. #5 Re: oil leak
    Jul 2008
    sumter,south carolina
    could always get some dye,see exactly where its comin from.
    02 GTP with mods 05 GP for DD
  1. A/C refrigerant leak
    By m0ng00se in forum General Tech Discussion
    Last Post: 04-15-2010, 10:15 PM
  2. Oil Leak, Which gasket?
    By HOPPY in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-20-2008, 01:07 AM
  3. fuel leak
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2008, 03:40 PM
  4. Oil leak
    By fiveinthelive in forum General Tech Discussion
    Last Post: 03-11-2008, 09:35 AM
  5. Oil leak problem
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2008, 05:24 AM
