Thread: Header Install Woes
Results 1 to 11 of 11
  1. #1 Header Install Woes
    Jacksonville
    So the Speed Daddy header install is not going so well. The crossover pipe is far enough out that I cannot bend it to fit the front manifold.
    Does anyone in the Jacksonville, FL area have a block with cylinder heads that I can use to fit up these headers so that they will install correctly in the car?
  2. #2 Re: Header Install Woes
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    Had the same issue but we took the front header off. Attatched it to the crossover, then we bolted the header backup slowly throughout the day lil by lil so it slowly bent the crossover, Hope that helps.
  3. #3 Re: Header Install Woes
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    ^^^^ you need to take the front header off then insert the crossover, then slowly bolt the front header back
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  4. #4 Re: Header Install Woes
    Jacksonville
    I tried doing that yesterday but the problem is that the angle of this setup is so far off that I can get one bolt in on the passenger side of the front header but then the driver's side is off by atleast 1.5".
    I'm going to try and bend where the crossover goes into the rear manifold with some heat and a hammer and see where that gets me.
  5. #5 Re: Header Install Woes
    And..you do have the pipe in the correct way?
    I've seen them be off and slowly but surely...i'd turn a few times with a wrench..tap the pipe.. and repeat until things came in line.
  6. #6 Re: Header Install Woes
    Jacksonville
    Should I leave the rear header loose when I am doing all of this
  7. #7 Re: Header Install Woes
    No..
  8. #8 Re: Header Install Woes
    I had an install like this it kinda sucked getting it in there but it eventually went.
  9. #9 Re: Header Install Woes
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    When I installed mine, everything was loose including the rear header. It takes some finesse...
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  10. #10 Re: Header Install Woes
    Geezus for the love of god please tell me you have the upper dog bones loose! The engine rocks back and forth super easy once you take the dog bones out and will be SOOOOOO much easier with more room if you don't have them off slap yourself then say thanks Vet.....................
  11. #11 Re: Header Install Woes
    Jacksonville
    The coil mount was off, dogbones off and a whole slew of things to go about installing the rear header from the top. I got the header in but it wasn't until I read another post by bill about dropping the rear of the cradle and coming in from the bottom that I found out it was 1000x easier that way.
    I ended up borrowing an engine from a mutual friend with a junkyard to mock-up the install. After I cut and welded the crossover the whole setup dropped right in.
    I am doing better on knock now, down to about 2 degrees on a stock pulley and cooler copper plugs. I need to weld in my wideband bung to see if I am running lean or what is going on.
  1. SD Header Install Soon...
    By theshznt69 in forum 04+ Specifics
    Last Post: 05-23-2010, 05:28 PM
  2. ZZP Header Install
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2010, 09:08 PM
  3. Header Install
    By GP_Kid18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2009, 11:12 PM
  4. S&S Header Install
    By GRANDPRIXFOOL01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2009, 09:57 PM
  5. my header install needs help
    By gtphayes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2009, 04:57 PM
