Thread: HELP AC Clutch wont kick in
Results 1 to 20 of 24
  1. #1 HELP AC Clutch wont kick in
    McKinney, Tx
    Well, I'll get right to it. A couple weeks ago I went to recharge the AC System but it would not take any freon and the gages didn't move. I then noticed that the AC Clutch was not kicking in. And when I Tested the Power going to it I got nothing. Someone mentioned that it might be a bad pressure switch, but I'm clueless. Any ideas???
  2. #2 Re: HELP AC Clutch wont kick in
    im no a/c pro but that does sound right. if you run power to the green wire on the plug to the compressor it should engage and then work.
    this is not meant to fix it, just to test the compressor, its power comes from that pressure switch i believe.
  3. #3 Re: HELP AC Clutch wont kick in
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    My wife's compressor wouldn't kick on a month or two ago. Stuck a gauge on it and put a can of R134 or whatever in it and it's been good for the last few months.
    Might just be low on refrigerant.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  4. #4 Re: HELP AC Clutch wont kick in
    Mar 2012
    South Beloit, IL
    Quote Originally Posted by buck531 View Post
    x2
    Same thing for me, the clutch has a pressure valve on it that won't allow it to engage unless there is enough freon in your system. Applying power to it basically overrides that fail safe.
  5. #5 Re: HELP AC Clutch wont kick in
    McKinney, Tx
    Pressure valve/ pressure switch... Same thing?
  6. #6 Re: HELP AC Clutch wont kick in
    Mar 2012
    South Beloit, IL
    Yeah. Whatever prevents the clutch from actuating when the pressure is not high enough. You'll hear it if you fill your system up with r134a and if your AC is "running". It will suddenly click on and you'll hear your engine increase it's load, you don't have to watch it. Also, your fans should start spinning faster to move more air across the radiator and AC condenser.
  7. #7 Re: HELP AC Clutch wont kick in
    McKinney, Tx
    Oh I see. Sorry nevermind . They are different. Any idea where the pressure SWITCH is located. And whether it would the high or low I would need to change out?
  8. #8 Re: HELP AC Clutch wont kick in
    Mar 2012
    South Beloit, IL
    Quick google search shows this if it helps:
    http://www.grandprixforums.net/where...tch-12772.html
  9. #9 Re: HELP AC Clutch wont kick in
    McKinney, Tx
    Awesome I'll try replacing the switch tomarrow and let ya'll know how it goes. Thanks for the help!
  10. #10 Re: HELP AC Clutch wont kick in
    McKinney, Tx
    Ok, so I tested the clutch straight from the battery and got the clutch to click on, thus confirming that it works. I then replaced the high side ac switch. Hooked up the gages and started the car but the clutch would not kick on. I started out with no freon and maybe got 1/4 of R134A into the system and with that both low and high side gages read 110. Still nothing from the AC Clutch. So i tested the clutch, replaced the ac switch, put in 110psi worth of R134A freon, checked fuses and tested relays. So I guess my clutch is not getting any voltage, what would cause it to not turn on?
  11. #11 Re: HELP AC Clutch wont kick in
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Low side switch is the one that needs looked at not the high side (if it's out of refrigerant)...Also have you done any other work on the car recently? Is your IAT sensor unplugged or failed?
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  12. #12 Re: HELP AC Clutch wont kick in
    McKinney, Tx
  13. #13 Re: HELP AC Clutch wont kick in
    McKinney, Tx
    Is that the switch your talking about?
  14. #14 Re: HELP AC Clutch wont kick in
    McKinney, Tx
    I also checked the Iat sensor and it shows to be good after testing it with a multimeter. The system did take a little refrigerant but was empty. Also checked the power going away from ac compressor for any shorts.
  15. #15 Re: HELP AC Clutch wont kick in
    McKinney, Tx
    ALSO... the only recent work I have done on the car is fix the two radiator fan motors.
  16. #16 Re: HELP AC Clutch wont kick in
    Quote Originally Posted by bbfanatic23 View Post
    in what way did you fix the fans?
    any chance they turn on when the ac is turned on? or when the compressor is jumped do they come on?
  17. #17 Re: HELP AC Clutch wont kick in
    McKinney, Tx
    I replaced them both, but one at time, as they went bad at different times in the last 6 months or so(first one got replaced because a snake found it to be a nice home). They don't turn on when i turn the ac on, but only once my car has reached 200ish degrees. Seems like a faulty thermostat to me when it comes to that problem. And I'm not 100% sure but I dont think the fans come on when I jumped the AC Compressor today.
  18. #18 Re: HELP AC Clutch wont kick in
    ok just checking if it was bad wires or a sensor.
    when the a/c is on, the fans should come on. maybe whats not sending power to the compressor's also not powering the fans.
  19. #19 Re: HELP AC Clutch wont kick in
    McKinney, Tx
    Ya maybe :/. What's your thought on it not being the high but low side sensor/switch/whatever they wanna call it?
  20. #20 Re: HELP AC Clutch wont kick in
    not sure, anything is possible tho.
  1. Cylinder 3 misfire when SC would kick in
    By Beelzeboul in forum General Tech Discussion
    Last Post: 08-21-2012, 08:20 AM
  2. Cooling Fan won't kick on
    By Jrodbrown58 in forum General Tech Discussion
    Last Post: 03-31-2010, 09:45 PM
  3. Kick Ass 11 Year Old
    Last Post: 09-13-2008, 01:55 AM
  4. Remember These Kick Ass Commercials?
    Last Post: 09-02-2008, 09:24 PM
