My 98 GTP has all this old brittle plastic vacuum line from the bypass valve to the MAP, is it safe to replace it all with rubber line and new Ts as needed?
Absolutely. And if you ever want to have original stuff again, GM sells a vacuum kit that includes all lines and fittings.
Yeah mine broke long ago. I now have a plastic T with rubber lines in its place.
i re-did all my vacuum lines with rubber, fits good and snug.
Does anyone have the part number for that kit or some other alternative with parts from advance or auto zone? Just replaced my lim and broke some vacuum ts. Firgured i go ahead and replace lines as well.Thanks.
Don't have the part number but I can tell you its around $70 from the dealer. Have you checked rock auto?
Ok your right......I'm wrong......i must have replace a different vac line but i can't tell you the one i bought from the dealer was $70. Relax.
Paid $12 for the replacement one I picked up from the dealer.. Someone got raped.
honestly. go buy a couple vacuum Ts at the auto parts. buy a crap ton of hose. and you can create even better vac lines than gm gave you
