Thread: making zzp modded fuel rail returnless
Results 1 to 14 of 14
  1. #1 making zzp modded fuel rail returnless
    Does anyone have any pics of how to do this? I have a zzp modded rail but would like to use it on my 04 comp g
  2. #2 Re: making zzp modded fuel rail returnless
    Hook up supply line, plug return line hole.
    Smutter..did you honestly just ask this?
  3. #3 Re: making zzp modded fuel rail returnless
    May 2008
    Schuyler, NE
    Want to buy a set of zzp returnless fuel rails instead?
  4. #4 Re: making zzp modded fuel rail returnless
    Yes I do. Do you have a set? Bill how do I plug it though?
  5. #5 Re: making zzp modded fuel rail returnless
    With an npt plug.. aren't all the fittings npt on it
  6. #6 Re: making zzp modded fuel rail returnless
    May 2008
    Schuyler, NE
    Yes, I have a new, never used/installed set. I'll get pic's tonight and send them.
  7. #7 Re: making zzp modded fuel rail returnless
    There was another guy.. Adecker I think asking about some in chat. Maybe shoot him a pm if Smutty Slutty isn't in for them.
  8. #8 Re: making zzp modded fuel rail returnless
    May 2008
    Schuyler, NE
    Awesome. Thanks Bill!
  9. #9 Re: making zzp modded fuel rail returnless
    I'm in for them. Makes my life easier. Pm me pics I'll send you some of my rail. ........... wait that sounds awful but I'm leaving it
  10. #10 Re: making zzp modded fuel rail returnless
    This is what I have bill
  11. #11 Re: making zzp modded fuel rail returnless
    Jan 2013
    Anderson SC
    ill buy the l67 rail and I also have a stock l67 or l32 rail
  12. #12 Re: making zzp modded fuel rail returnless
    SE Level Member reallyfast1's Avatar
    Aug 2008
    CAMBRIDGE,ONTARIO,CANADA
    All u have to do is go to home depot get a 3/8 brass pressure fitting with a 3/8 cap I made my own need info pm me
  13. #13 Re: making zzp modded fuel rail returnless
    Quote Originally Posted by reallyfast1 View Post
    Happen to have a pic of it? I'm wanting to ic tom and think I might take a half day to get it done before the car show tom night.
  14. #14 Re: making zzp modded fuel rail returnless
    Aug 2008
    This is the piece to screw on the cut off end of zzp return side. I cut off before the regulator and capped it there. It will have crush sleves to go on the tube after the nut!
    No. 62-R Tube to Tube Reducing Unions, Compression Fittings, Brass &#38; Tubular - Watts Canada
    This is the cap to go on the other side of the fitting, I used JB weld as a thread sealer and locker.. edges of tube must be smooth inside and out for it to seal good along with it being on pretty tight to crush the sleve as well!
    No. 61-CX Brass Compression Caps - Less Insert, Compression Fittings, Brass &#38; Tubular - Watts Canada
    u want 3/8" need any more info shoot me a PM
  1. Replies: 19
    Last Post: 10-20-2015, 09:22 PM
  2. L32 Returnless Fuel system question
    By FirstGen FBody in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-28-2010, 03:17 PM
