Does anyone have any pics of how to do this? I have a zzp modded rail but would like to use it on my 04 comp g
Hook up supply line, plug return line hole.
Smutter..did you honestly just ask this?
Want to buy a set of zzp returnless fuel rails instead?
Yes I do. Do you have a set? Bill how do I plug it though?
Yes, I have a new, never used/installed set. I'll get pic's tonight and send them.
There was another guy.. Adecker I think asking about some in chat. Maybe shoot him a pm if Smutty Slutty isn't in for them.
Awesome. Thanks Bill!
I'm in for them. Makes my life easier. Pm me pics I'll send you some of my rail. ........... wait that sounds awful but I'm leaving it
ill buy the l67 rail and I also have a stock l67 or l32 rail
This is the piece to screw on the cut off end of zzp return side. I cut off before the regulator and capped it there. It will have crush sleves to go on the tube after the nut!
No. 62-R Tube to Tube Reducing Unions, Compression Fittings, Brass & Tubular - Watts Canada
This is the cap to go on the other side of the fitting, I used JB weld as a thread sealer and locker.. edges of tube must be smooth inside and out for it to seal good along with it being on pretty tight to crush the sleve as well!
No. 61-CX Brass Compression Caps - Less Insert, Compression Fittings, Brass & Tubular - Watts Canada
u want 3/8" need any more info shoot me a PM
